[petsc-dev] PETSc 3.5.0 compilation on Windows and OpenMP with pthread
Thu Jul 3 08:34:32 CDT 2014
On Thu, 3 Jul 2014, Jed Brown wrote:
> Baros Vladimir <vbaros at hsr.ch> writes:
> > previously I successfully built PETSc with Intel compiler (the last
> > successful build was 3.4.4) using OpenMP libraries.
> > In version 3.5.0, OpenMP package depends on pthread library which
> > doesn't exist on Windows.  Why this new requirement and what do you
> > recommend to use on Windows?
> Your old Windows configuration of PETSc was not actually using OpenMP.
> The threaded implementations use a "thread communicator" which was
> activated by the optional package "pthreadclasses".  OpenMP is not used
> by PETSc without "threadcomm" and we are refactoring the whole thing so
> please don't use it at this time.
threadcomm.py is disabled in petsc3.4, 3.5. Should pthreadclasses.py also be
disabled? [should openmp.py also be disabled?]
https://bitbucket.org/petsc/petsc/commits/6e5884b57154c4018286842049a07306848380f9#chg-config/PETSc/packages/threadcomm.py
Satish
