[petsc-dev] PETSc 3.5.0 compilation on Windows and OpenMP with pthread
Jed Brown jed at jedbrown.org
Thu Jul 3 08:37:39 CDT 2014
Satish Balay <balay at mcs.anl.gov> writes:
> threadcomm.py is disabled in petsc3.4, 3.5. Should pthreadclasses.py also be
> disabled? [should openmp.py also be disabled?]
> https://bitbucket.org/petsc/petsc/commits/6e5884b57154c4018286842049a07306848380f9#chg-config/PETSc/packages/threadcomm.py
Yes, they can't do anything but cause confusion right now, and the
legacy "pthreadclasses" option should go away.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140703/44f9a87e/attachment.sig>
