[petsc-dev] Need -lfl in c2html
Jed Brown jed at jedbrown.org
Sun Feb 23 13:08:11 CST 2014
Satish Balay <balay at mcs.anl.gov> writes:
> On Sun, 23 Feb 2014, Satish Balay wrote:
>> > Also note that there is a newer c2html.
>> > Now it doesn't delight me that c2html's configure script has been edited
>> > From the one generated by autoconf.
> Are you sure its modified?
I see tests in configure (for yywrap) that don't exist in configure.in.
My explanation of this is that someone ran autoconf a long time ago,
then modified configure, but it could be wrong.  Current autoconf fails.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140223/0dccf42b/attachment.sig>
