[petsc-dev] Need -lfl in c2html
Sun Feb 23 12:51:20 CST 2014
On Sun, 23 Feb 2014, Satish Balay wrote:
> > Also note that there is a newer c2html.
> > Now it doesn't delight me that c2html's configure script has been edited
> > From the one generated by autoconf.
Are you sure its modified? Looking at it - we didn't do any
modifications [to configure] - but I see we are carrying the following
patch - perhaps to supress warnings
$ diff -Nru c2html-0.9.4-orig/ c2html-0.9.4/
diff -Nru c2html-0.9.4-orig/Makefile.in c2html-0.9.4/Makefile.in
--- c2html-0.9.4-orig/Makefile.in       2001-11-22 03:05:46.000000000 -0600
+++ c2html-0.9.4/Makefile.in            2005-01-31 17:22:36.000000000 -0600
@@ -59,8 +59,7 @@
 docdir          = @DOCDIR@
 CPPFLAGS        = @CPPFLAGS@
-CFLAGS += -O2 -Wall
-ALL_CFLAGS = $(CFLAGS) -I$(srcdir) -I. $(COMPRESSION)
+ALL_CFLAGS = $(CFLAGS) -O -I$(srcdir) -I. $(COMPRESSION)
 all: $(TARGET)
Also - I see upsteam is using old 'Autoconf 2.52' - I guess this
shouldn't matter.
Satish
