[petsc-dev] Need -lfl in c2html
Sun Feb 23 13:52:44 CST 2014
On Sun, 23 Feb 2014, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> > On Sun, 23 Feb 2014, Satish Balay wrote:
> >> > Also note that there is a newer c2html.
> >> > Now it doesn't delight me that c2html's configure script has been edited
> >> > From the one generated by autoconf.
> > Are you sure its modified?
> I see tests in configure (for yywrap) that don't exist in configure.in.
> My explanation of this is that someone ran autoconf a long time ago,
> then modified configure, but it could be wrong.  Current autoconf fails.
Hm current autoconf works fine for me. Or is the failure you refer to
the same wrt to detecting the new flex?
Satish
balay at asterix /home/balay/tmp/c2html-0.9.4
$ autoconf --version
autoconf (GNU Autoconf) 2.69
Copyright (C) 2012 Free Software Foundation, Inc.
License GPLv3+/Autoconf: GNU GPL version 3 or later
<http://gnu.org/licenses/gpl.html>, <http://gnu.org/licenses/exceptions.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Written by David J. MacKenzie and Akim Demaille.
$ autoconf
$ ./configure
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for a BSD-compatible install... /usr/bin/install -c
checking for flex... flex
checking lex output file root... lex.yy
checking lex library... -lfl
checking whether yytext is a pointer... yes
checking whether make sets $(MAKE)... yes
checking for yylex in -lfl... no
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /usr/bin/grep
checking for egrep... /usr/bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for unistd.h... (cached) yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking malloc.h usability... yes
checking malloc.h presence... yes
checking for malloc.h... yes
checking for an ANSI C-conforming const... yes
checking for uid_t in sys/types.h... yes
checking for mode_t... yes
checking for off_t... yes
checking for pid_t... yes
checking for size_t... yes
checking for stdlib.h... (cached) yes
checking for sys/param.h... yes
checking for getpagesize... yes
checking for working mmap... yes
checking for strftime... yes
checking for strstr... yes
checking for getopt... yes
checking for popen... yes
checking for fileno... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: WARNING:  'Makefile.in' seems to ignore the --datarootdir setting
config.status: creating config.h
$ make
flex ./c2html.l
gcc  -O -I. -I. -DCOMPRESSION=1  -o c2html lex.yy.c ./mymain.c ./colors.c -lfl
