[petsc-dev] workflow diagram
Jed Brown jed at jedbrown.org
Wed Apr 30 13:16:59 CDT 2014
Peter Brune <prbrune at gmail.com> writes:
> Looks good.  Directionality on the interbranch features via arrowheads
> might give it a bit more of a flow-like feel.
Done.  (I think this is what you had in mind.)
> Lining up commits that are supposed to correspond and/or marking
> merges in a particular way special might also make it prettier and
> more intuitive.
Merges are marked in a different color now.  How would you change that?
(If it's hard to describe, maybe make a copy of the document and propose
a change.)
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140430/e9c34b25/attachment.sig>
