[petsc-dev] workflow diagram
Peter Brune prbrune at gmail.com
Wed Apr 30 13:05:49 CDT 2014
Looks good.  Directionality on the interbranch features via arrowheads
might give it a bit more of a flow-like feel.  Lining up commits that are
supposed to correspond and/or marking merges in a particular way special
might also make it prettier and more intuitive.
- Peter
On Wed, Apr 30, 2014 at 12:57 PM, Jed Brown <jed at jedbrown.org> wrote:
> This is my first attempt at a diagram to explain our workflow.  Let me
> know what you think about it.  I will probably write a blog post later
> to explain the properties and rationale behind this workflow relative to
> others.
> https://docs.google.com/drawings/d/1hvwyCIw4Wq3NoRrPpWfPTriJn5MM2_QkaacAaql8FQE/edit
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140430/831dcd8b/attachment.html>
