[petsc-dev] workflow diagram
Jed Brown jed at jedbrown.org
Wed Apr 30 12:57:35 CDT 2014
This is my first attempt at a diagram to explain our workflow.  Let me
know what you think about it.  I will probably write a blog post later
to explain the properties and rationale behind this workflow relative to
others.
https://docs.google.com/drawings/d/1hvwyCIw4Wq3NoRrPpWfPTriJn5MM2_QkaacAaql8FQE/edit
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140430/66d8d6db/attachment.sig>
