[petsc-dev] PETSC_VERSION_GE
Ed D'Azevedo dazevedoef at ornl.gov
Wed Apr 16 09:41:18 CDT 2014
Hi Mark,
I hope this back trace might be helpful.
You may need to build petsc with
./configure \
--with-x=0 \
--with-debugging=0 \
--with-log=0 \
env003> addr2line --exe=tpetsc_madams 0x4b76e3 0x4aa3d7 0x484888
0x475798 0x548aa5 0x5e5df2 0x57a353 0x4a701e  0x44e9be 0x44e1f4
/autofs/na3_home1/adams/petsc/src/sys/memory/mal.c:27
/autofs/na3_home1/adams/petsc/src/sys/utils/str.c:188
/autofs/na3_home1/adams/petsc/src/sys/logging/utils/eventlog.c:317
/autofs/na3_home1/adams/petsc/src/sys/logging/plog.c:747
/autofs/na3_home1/adams/petsc/src/mat/interface/dlregismat.c:145
/autofs/na3_home1/adams/petsc/src/mat/utils/gcreate.c:57
/autofs/na3_home1/adams/petsc/src/mat/impls/aij/seq/aij.c:3576
/autofs/na3_home1/adams/petsc/src/mat/impls/aij/seq/ftn-custom/zaijf.c:14
/autofs/na3_home1/efdazedo/test/PETSC/./tpetsc.F90:147
======= Backtrace: =========
/lib64/libc.so.6(+0x75558)[0x2aaaba5ff558]
/lib64/libc.so.6(cfree+0x6c)[0x2aaaba6044fc]
./tpetsc_madams[0x4b7759]
   /lib64/libpthread.so.0(+0xf7c0) [0x2aaaaacdb7c0]
   /lib64/libc.so.6(gsignal+0x35) [0x2aaaba5bcb55]
   /lib64/libc.so.6(abort+0x181) [0x2aaaba5be131]
   /lib64/libc.so.6(+0x7576d) [0x2aaaba5ff76d]
   /lib64/libc.so.6(+0x789f0) [0x2aaaba6029f0]
   /lib64/libc.so.6(__libc_malloc+0x77) [0x2aaaba6045e7]
   ./tpetsc_madams() [0x4b76e3]
   ./tpetsc_madams() [0x4aa3d7]
   ./tpetsc_madams() [0x484888]
   ./tpetsc_madams() [0x475798]
   ./tpetsc_madams() [0x548aa5]
   ./tpetsc_madams() [0x5e5df2]
   ./tpetsc_madams() [0x57a353]
   ./tpetsc_madams() [0x4a701e]
   ./tpetsc_madams() [0x44e9be]
   ./tpetsc_madams() [0x44e1f4]
   /lib64/libc.so.6(__libc_start_main+0xe6) [0x2aaaba5a8c36]
   ./tpetsc_madams() [0x44e0e9]
On 04/16/2014 10:33 AM, Mark Adams wrote:
> cc'ing petsc-dev.
> I will try it.
> On Wed, Apr 16, 2014 at 10:21 AM, Ed D'Azevedo <dazevedoef at ornl.gov
> <mailto:dazevedoef at ornl.gov>> wrote:
>     Hi Mark,
>     I got an error when I tried the simple test code (see attached) on
>     Titan.
>     Can you try to run the attached test case to see if it will work
>     for you?
>     I have also sent the simple test code to Barry.
>     The code seems to work with 1 thread
>     env003> export OMP_NUM_THREADS=1
>     env003> aprun -n 1 -d 16 ./tpetsc_madams
>      PETSC_VERSION_RELEASE               0
>      PETSC_VERSION_MAJOR                 3
>      PETSC_VERSION_MINOR                 4
>      PETSC_VERSION_SUBMINOR              4
>      PETSC_VERSION_PATCH                 0
>      PETSC_VERSION_DATE      unknown
>      petsc_version_lt(3,3,0) is false
>      nthreads =             1  NCASES =           100
>      nz =         88804
>     Warning: ieee_inexact is signaling
>     all done
>      total time is     7.268438
>      maxval(err)    6.9650285539069046E-011
>     Application 4895013 resources: utime ~8s, stime ~0s, Rss ~22300,
>     inblocks ~11428, outblocks ~35848
>     The code seems to have trouble using more threads
>     env003> export OMP_NUM_THREADS=16
>     *** glibc detected *** ./tpetsc_madams: double free or corruption
>     (!prev): 0x00000000015ee0b0 ***
>      nthreads =            16  NCASES =           100
>     tpetsc_madams: malloc.c:3091: sYSMALLOc: Assertion `(old_top ==
>     (((mbinptr) (((char *) &((av)->bins[((1) - 1) * 2])) -
>     __builtin_offsetof (struct malloc_chunk, fd)))) && old_size == 0)
>     || ((unsigned long) (old_size) >= (unsigned
>     long)((((__builtin_offsetof (struct malloc_chunk,
>     fd_nextsize))+((2 * (sizeof(size_t))) - 1)) & ~((2 *
>     (sizeof(size_t))) - 1))) && ((old_top)->size & 0x1) && ((unsigned
>     long)old_end & pagemask) == 0)' failed.
>     Error: abort
>        rax 0000000000000000, rbx 0000000000000fff, rcx ffffffffffffffff
>        rdx 0000000000000006, rsp 00002aaac4554f78, rbp 00002aaad0000098
>        rsi 0000000000005200, rdi 00000000000051f1, r8 00000000ffffffff
>        r9  00002aaaba8f9e40, r10 0000000000000008, r11 0000000000000202
>        r12 0000000000000000, r13 00002aaad0008e30, r14 0000000000000020
>        r15 0000000000000000
>     Application 4895021 exit codes: 127
>     Application 4895021 resources: utime ~0s, stime ~0s, Rss ~12544,
>     inblocks ~11429, outblocks ~35849
>     On 04/11/2014 04:34 PM, Mark Adams wrote:
>>     PETSc dev 'master' now has Barry's thread safe stuff so you
>>     should be able to use that.  I have build it in:
>>     PETSC_DIR=/autofs/na3_home1/adams/petsc
>>     PETSC_ARCH=arch-titan-opt
>>     So try this version out.  And revert the code to the repo version
>>     by doing:
>>     > git checkout poisson.F90
>>     and any other place where #if PETSC_VERSION_GE(3,5,0) is used.  I
>>     only see poisson.F90.
>>     If this works I can install it wherever you like as Ed did.
>>     Mark
>>     On Thu, Apr 10, 2014 at 11:24 PM, Seung-Hoe Ku <sku at pppl.gov
>>     <mailto:sku at pppl.gov>> wrote:
>>         Hi Mark,
>>         I think it is not a big problem until we use petsc 3.5 other
>>         than you. Now I disabled #if #endif for other users. Sorry
>>         for the inconvenience. Could you uncomment it when you are
>>         working with 3.5, and does not commit to core_dev, please?
>>         We need Ed's thread safe petsc for performance issue, so we
>>         can find some way to resolve it when 3.5 is released and
>>         installed on titan.
>>         Thanks,
>>         Seung-Hoe
>>         On Thu, Apr 10, 2014 at 11:38 AM, Mark Adams <mfadams at lbl.gov
>>         <mailto:mfadams at lbl.gov>> wrote:
>>             We've figured out the problem (again).  It will be fixed
>>             in future versions.
>>             We can fix your installation.  I'm guessing Ed did this
>>             installation so it might not be worth fixing this code
>>             since you are up and running.  Let me know what you want
>>             to do.
>>             The problem is that is a development version of the code,
>>             which is not as stable as the releases.  This version
>>             needs to be updated to get fix this problem.  I have to
>>             tell you how to do this update so let me know if you want
>>             to do it.
>>             Mark
>>             On Thu, Apr 10, 2014 at 8:58 AM, Seung-Hoe Ku
>>             <sku at pppl.gov <mailto:sku at pppl.gov>> wrote:
>>                 One question is..
>>                 If PETSC_VERSION_GE is defined with PETSC_VERSION_GT
>>                 and PETSC_VERSION_GT is defined with something in
>>                 petsc.h,
>>                 redefinition of PETSC_VERSION_GT after petsc.h will
>>                 change PETSC_VERSION_GE?
>>                 On Thu, Apr 10, 2014 at 10:55 AM, Seung-Hoe Ku
>>                     This is the code I tried to compile.
>>                     #if PETSC_VERSION_GE(5,5,0)
>>                      214 BBBBBBBBBBBBBBBBBBB=0
>>                      215   call KSPSetOperators(solver%ksp,
>>                     solver%Amat, solver%Amat, ierr )
>>                      216 #else
>>                      217 AAAAAAAAAAAA=0
>>                      218   call KSPSetOperators(solver%ksp,
>>                     solver%Amat, solver%Amat, SAME_NONZERO_PATT ERN,
>>                     ierr )
>>                      219 #endif
>>                     On Thu, Apr 10, 2014 at 10:49 AM, Mark Adams
>>                     <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>>                         On Thu, Apr 10, 2014 at 8:25 AM, Seung-Hoe Ku
>>                             I have the same problem. I used
>>                             poisson.F90 in
>>                             /lustre/atlas2/env003/scratch/shku/XGC1_3_petsc_problem/
>>                             It seems that #undef should be after
>>                             #include<finclude/petsc.h>. Otherwise,
>>                             petsc.h seems to try redefine it.
>>                         Oh yes.
>>                             Anyway, I got the same error message:
>>                             PGF90-S-0038-Symbol, bbbbbbbbbbbbbbbbbbb,
>>                             has not been explicitly declared
>>                             (poisson.F90)
>>                               0 inform, 0 warnings, 1 severes, 0
>>                             fatal for init_1field_solver
>>                         is this in the source file?
>>                             I tried 5.5.0 for the arguments of
>>                             PETSC_VERSION_GE, but still have the same
>>                             problem.
>>                             Or do you mean VERSION_GE and VERSION_LT
>>                             instead of VERSION_GT and VERSION_LE?
>>                             Thanks,
>>                             Seung-Hoe
>>                             On Wed, Apr 9, 2014 at 9:54 PM, Mark
>>                                 We might have a fix.  It turns out
>>                                 that some fortran compilers to not do
>>                                 the #define quite right. Try this:
>>                                 This will out the original (bad) file
>>                                 back. Then add to poisson.F90
>>                                 #undef PETSC_VERSION_GT
>>                                 #define
>>                                 PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
>>                                 (0==PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR))
>>                                 This is the fix that Jed thinks will
>>                                 work.  If it works we can propagate it.
>>                                 Sorry about the confusion,
>>                                 Mark
>>                                 On Wed, Apr 9, 2014 at 7:36 PM,
>>                                     Great! Thank you.
>>                                     On Wed, Apr 9, 2014 at 9:35 PM,
>>                                         Good news.  I'm at a meeting
>>                                         and Jed Brown is here and he
>>                                         seems to have been able to
>>                                         reproduce the error.
>>                                          Preprocessors can be a pain.
>>                                          I'm going to wait until Jed
>>                                         has a chance to look at this
>>                                         and come up with a solution.
>>                                         On Wed, Apr 9, 2014 at 7:28
>>                                         PM, Seung-Hoe Ku
>>                                         <sku at pppl.gov
>>                                             Now I am using iterative
>>                                             solver which will be
>>                                             replaced to your 2 field
>>                                             solver later.
>>                                             Sorry. The line number
>>                                             3003 is wrong. It is  209
>>                                             or near it.
>>                                             Yes. We can take a look
>>                                             at this when you come. It
>>                                             is not urgent problem.
>>                                             Thanks,
>>                                             Seung-Hoe
>>                                             9:25 PM, Mark Adams
>>                                             <mfadams at lbl.gov
>>                                             wrote:
>>                                                 I noticed that your
>>                                                 makefile was not
>>                                                 using the new petsc
>>                                                 solver.  Is that
>>                                                 intensional?
>>                                                 The line you gave me
>>                                                 3003 poission.F90
>>                                                 seems to be the last
>>                                                 line of the file.
>>                                                 I am not getting
>>                                                 Edison or Titan to
>>                                                 build.  We can take a
>>                                                 look at this next week.
>>                                                 Mark
>>                                                 On Tue, Apr 8, 2014
>>                                                 at 12:38 PM,
>>                                                 Seung-Hoe Ku
>>                                                 <sku at pppl.gov
>>                                                     Hi Mark,
>>                                                     It seems that
>>                                                     PETSC_VERSION_GE
>>                                                     is not working
>>                                                     line 3003 of
>>                                                     poisson.F90. Is
>>                                                     there any reason
>>                                                     of using
>>                                                     PETSC_VERSION_GE
>>                                                     instead of
>>                                                     PETSC_VERSION_LE?
>>                                                     The previous code
>>                                                     worked, I think.
>>                                                     Thanks,
>>                                                     Seung-Hoe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140416/2b3ddf60/attachment.html>
