[petsc-dev] PETSC_VERSION_GE
Mark Adams mfadams at lbl.gov
Wed Apr 16 10:24:36 CDT 2014
Ed, I have to run but I found that the second argument to split_indices was
called with a PetscInt but typed as an integer.
On Wed, Apr 16, 2014 at 10:41 AM, Ed D'Azevedo <dazevedoef at ornl.gov> wrote:
>  Hi Mark,
> I hope this back trace might be helpful.
> You may need to build petsc with
> ./configure \
> --with-x=0 \
> --with-debugging=0 \
> --with-log=0 \
> env003> addr2line --exe=tpetsc_madams 0x4b76e3 0x4aa3d7 0x484888 0x475798
> 0x548aa5 0x5e5df2 0x57a353 0x4a701e  0x44e9be 0x44e1f4
> /autofs/na3_home1/adams/petsc/src/sys/memory/mal.c:27
> /autofs/na3_home1/adams/petsc/src/sys/utils/str.c:188
> /autofs/na3_home1/adams/petsc/src/sys/logging/utils/eventlog.c:317
> /autofs/na3_home1/adams/petsc/src/sys/logging/plog.c:747
> /autofs/na3_home1/adams/petsc/src/mat/interface/dlregismat.c:145
> /autofs/na3_home1/adams/petsc/src/mat/utils/gcreate.c:57
> /autofs/na3_home1/adams/petsc/src/mat/impls/aij/seq/aij.c:3576
> /autofs/na3_home1/adams/petsc/src/mat/impls/aij/seq/ftn-custom/zaijf.c:14
> /autofs/na3_home1/efdazedo/test/PETSC/./tpetsc.F90:147
> ======= Backtrace: =========
> /lib64/libc.so.6(+0x75558)[0x2aaaba5ff558]
> /lib64/libc.so.6(cfree+0x6c)[0x2aaaba6044fc]
> ./tpetsc_madams[0x4b7759]
>   /lib64/libpthread.so.0(+0xf7c0) [0x2aaaaacdb7c0]
>   /lib64/libc.so.6(gsignal+0x35) [0x2aaaba5bcb55]
>   /lib64/libc.so.6(abort+0x181) [0x2aaaba5be131]
>   /lib64/libc.so.6(+0x7576d) [0x2aaaba5ff76d]
>   /lib64/libc.so.6(+0x789f0) [0x2aaaba6029f0]
>   /lib64/libc.so.6(__libc_malloc+0x77) [0x2aaaba6045e7]
>   ./tpetsc_madams() [0x4b76e3]
>   ./tpetsc_madams() [0x4aa3d7]
>   ./tpetsc_madams() [0x484888]
>   ./tpetsc_madams() [0x475798]
>   ./tpetsc_madams() [0x548aa5]
>   ./tpetsc_madams() [0x5e5df2]
>   ./tpetsc_madams() [0x57a353]
>   ./tpetsc_madams() [0x4a701e]
>   ./tpetsc_madams() [0x44e9be]
>   ./tpetsc_madams() [0x44e1f4]
>   /lib64/libc.so.6(__libc_start_main+0xe6) [0x2aaaba5a8c36]
>   ./tpetsc_madams() [0x44e0e9]
> On 04/16/2014 10:33 AM, Mark Adams wrote:
> cc'ing petsc-dev.
>  I will try it.
> On Wed, Apr 16, 2014 at 10:21 AM, Ed D'Azevedo <dazevedoef at ornl.gov>wrote:
>> Hi Mark,
>> I got an error when I tried the simple test code (see attached) on Titan.
>> Can you try to run the attached test case to see if it will work for you?
>> I have also sent the simple test code to Barry.
>> The code seems to work with 1 thread
>> env003> export OMP_NUM_THREADS=1
>> env003> aprun -n 1 -d 16 ./tpetsc_madams
>>  PETSC_VERSION_RELEASE               0
>>  PETSC_VERSION_MAJOR                 3
>>  PETSC_VERSION_MINOR                 4
>>  PETSC_VERSION_SUBMINOR              4
>>  PETSC_VERSION_PATCH                 0
>>  PETSC_VERSION_DATE      unknown
>>  petsc_version_lt(3,3,0) is false
>>  nthreads =             1  NCASES =           100
>>  nz =         88804
>> Warning: ieee_inexact is signaling
>> all done
>>  total time is     7.268438
>>  maxval(err)    6.9650285539069046E-011
>> Application 4895013 resources: utime ~8s, stime ~0s, Rss ~22300, inblocks
>> ~11428, outblocks ~35848
>> The code seems to have trouble using more threads
>> env003> export OMP_NUM_THREADS=16
>> *** glibc detected *** ./tpetsc_madams: double free or corruption
>> (!prev): 0x00000000015ee0b0 ***
>>  nthreads =            16  NCASES =           100
>> tpetsc_madams: malloc.c:3091: sYSMALLOc: Assertion `(old_top ==
>> (((mbinptr) (((char *) &((av)->bins[((1) - 1) * 2])) - __builtin_offsetof
>> (struct malloc_chunk, fd)))) && old_size == 0) || ((unsigned long)
>> (old_size) >= (unsigned long)((((__builtin_offsetof (struct malloc_chunk,
>> fd_nextsize))+((2 * (sizeof(size_t))) - 1)) & ~((2 * (sizeof(size_t))) -
>> 1))) && ((old_top)->size & 0x1) && ((unsigned long)old_end & pagemask) ==
>> 0)' failed.
>> Error: abort
>>    rax 0000000000000000, rbx 0000000000000fff, rcx ffffffffffffffff
>>    rdx 0000000000000006, rsp 00002aaac4554f78, rbp 00002aaad0000098
>>    rsi 0000000000005200, rdi 00000000000051f1, r8  00000000ffffffff
>>    r9  00002aaaba8f9e40, r10 0000000000000008, r11 0000000000000202
>>    r12 0000000000000000, r13 00002aaad0008e30, r14 0000000000000020
>>    r15 0000000000000000
>> Application 4895021 exit codes: 127
>> Application 4895021 resources: utime ~0s, stime ~0s, Rss ~12544, inblocks
>> ~11429, outblocks ~35849
>> On 04/11/2014 04:34 PM, Mark Adams wrote:
>> PETSc dev 'master' now has Barry's thread safe stuff so you should be
>> able to use that.  I have build it in:
>>  PETSC_DIR=/autofs/na3_home1/adams/petsc
>> PETSC_ARCH=arch-titan-opt
>>  So try this version out.  And revert the code to the repo version by
>> doing:
>>  > git checkout poisson.F90
>>  and any other place where #if PETSC_VERSION_GE(3,5,0) is used.  I only
>> see poisson.F90.
>>  If this works I can install it wherever you like as Ed did.
>>  Mark
>>  On Thu, Apr 10, 2014 at 11:24 PM, Seung-Hoe Ku <sku at pppl.gov> wrote:
>>>   Hi Mark,
>>> I think it is not a big problem until we use petsc 3.5 other than you.
>>> Now I disabled #if #endif for other users. Sorry for the inconvenience.
>>> Could you uncomment it when you are working with 3.5, and does not commit
>>> to core_dev, please?
>>>  We need Ed's thread safe petsc for performance issue, so we can find
>>> some way to resolve it when 3.5 is released and installed on titan.
>>>  Thanks,
>>>  Seung-Hoe
>>> On Thu, Apr 10, 2014 at 11:38 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>> We've figured out the problem (again).  It will be fixed in future
>>>> versions.
>>>>  We can fix your installation.  I'm guessing Ed did this installation
>>>> so it might not be worth fixing this code since you are up and running.
>>>>  Let me know what you want to do.
>>>>  The problem is that is a development version of the code, which is
>>>> not as stable as the releases.  This version needs to be updated to get fix
>>>> this problem.  I have to tell you how to do this update so let me know if
>>>> you want to do it.
>>>>  Mark
>>>> On Thu, Apr 10, 2014 at 8:58 AM, Seung-Hoe Ku <sku at pppl.gov> wrote:
>>>>>  One question is..
>>>>>  If PETSC_VERSION_GE is defined with PETSC_VERSION_GT and
>>>>> PETSC_VERSION_GT is defined with something in petsc.h,
>>>>>  redefinition of PETSC_VERSION_GT after petsc.h will change
>>>>> PETSC_VERSION_GE?
>>>>> On Thu, Apr 10, 2014 at 10:55 AM, Seung-Hoe Ku <sku at pppl.gov> wrote:
>>>>>> This is the code I tried to compile.
>>>>>> #if PETSC_VERSION_GE(5,5,0)
>>>>>>  214   BBBBBBBBBBBBBBBBBBB=0
>>>>>>  215   call KSPSetOperators(solver%ksp,  solver%Amat,  solver%Amat,
>>>>>> ierr )
>>>>>>  216 #else
>>>>>>  217   AAAAAAAAAAAA=0
>>>>>>  218   call KSPSetOperators(solver%ksp,  solver%Amat,  solver%Amat,
>>>>>> SAME_NONZERO_PATT     ERN, ierr )
>>>>>>  219 #endif
>>>>>>  On Thu, Apr 10, 2014 at 10:49 AM, Mark Adams <mfadams at lbl.gov>wrote:
>>>>>>>  On Thu, Apr 10, 2014 at 8:25 AM, Seung-Hoe Ku <sku at pppl.gov> wrote:
>>>>>>>>    I have the same problem. I used poisson.F90 in
>>>>>>>> /lustre/atlas2/env003/scratch/shku/XGC1_3_petsc_problem/
>>>>>>>>  It seems that #undef should be after #include<finclude/petsc.h>.
>>>>>>>> Otherwise, petsc.h seems to try redefine it.
>>>>>>>  Oh yes.
>>>>>>>>   Anyway, I got the same error message:
>>>>>>>> PGF90-S-0038-Symbol, bbbbbbbbbbbbbbbbbbb, has not been explicitly
>>>>>>>> declared (poisson.F90)
>>>>>>>>   0 inform,   0 warnings,   1 severes, 0 fatal for
>>>>>>>> init_1field_solver
>>>>>>>  is this in the source file?
>>>>>>>>     I tried 5.5.0 for the arguments of PETSC_VERSION_GE, but still
>>>>>>>>  Or do you mean VERSION_GE and VERSION_LT instead of VERSION_GT and
>>>>>>>> VERSION_LE?
>>>>>>>>  Thanks,
>>>>>>>>  Seung-Hoe
>>>>>>>> On Wed, Apr 9, 2014 at 9:54 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>>> We might have a fix.  It turns out that some fortran compilers to
>>>>>>>>> not do the #define quite right. Try this:
>>>>>>>>>  This will out the original (bad) file back. Then add to
>>>>>>>>> poisson.F90
>>>>>>>>>  #undef PETSC_VERSION_GT
>>>>>>>>>  #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
>>>>>>>>>   (0==PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR))
>>>>>>>>>   This is the fix that Jed thinks will work.  If it works we can
>>>>>>>>> propagate it.
>>>>>>>>>  Sorry about the confusion,
>>>>>>>>> Mark
>>>>>>>>> On Wed, Apr 9, 2014 at 7:36 PM, Seung-Hoe Ku <sku at pppl.gov> wrote:
>>>>>>>>>> Great! Thank you.
>>>>>>>>>>  On Wed, Apr 9, 2014 at 9:35 PM, Mark Adams <mfadams at lbl.gov>wrote:
>>>>>>>>>>> Good news.  I'm at a meeting and Jed Brown is here and he seems
>>>>>>>>>>> to have been able to reproduce the error.  Preprocessors can be a pain.
>>>>>>>>>>>  I'm going to wait until Jed has a chance to look at this and come up with
>>>>>>>>>>> a solution.
>>>>>>>>>>> On Wed, Apr 9, 2014 at 7:28 PM, Seung-Hoe Ku <sku at pppl.gov>wrote:
>>>>>>>>>>>>  Now I am using iterative solver which will be replaced to
>>>>>>>>>>>> your 2 field solver later.
>>>>>>>>>>>> Sorry. The line number 3003 is wrong. It is  209 or near it.
>>>>>>>>>>>>  Yes. We can take a look at this when you come. It is not
>>>>>>>>>>>> urgent problem.
>>>>>>>>>>>>  Thanks,
>>>>>>>>>>>> Seung-Hoe
>>>>>>>>>>>> On Wed, Apr 9, 2014 at 9:25 PM, Mark Adams <mfadams at lbl.gov>wrote:
>>>>>>>>>>>>> I noticed that your makefile was not using the new petsc
>>>>>>>>>>>>> solver.  Is that intensional?
>>>>>>>>>>>>>  The line you gave me 3003 poission.F90 seems to be the last
>>>>>>>>>>>>> line of the file.
>>>>>>>>>>>>>  I am not getting Edison or Titan to build.  We can take a
>>>>>>>>>>>>> look at this next week.
>>>>>>>>>>>>>  Mark
>>>>>>>>>>>>> On Tue, Apr 8, 2014 at 12:38 PM, Seung-Hoe Ku <sku at pppl.gov>wrote:
>>>>>>>>>>>>>>  Hi Mark,
>>>>>>>>>>>>>>  It seems that PETSC_VERSION_GE is not working line 3003 of
>>>>>>>>>>>>>> poisson.F90. Is there any reason of using PETSC_VERSION_GE instead of
>>>>>>>>>>>>>> PETSC_VERSION_LE? The previous code worked, I think.
>>>>>>>>>>>>>>  Thanks,
>>>>>>>>>>>>>> Seung-Hoe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140416/62889811/attachment.html>
