[petsc-dev] PETSC_VERSION_GE
Mark Adams mfadams at lbl.gov
Wed Apr 16 09:33:33 CDT 2014
cc'ing petsc-dev.
I will try it.
On Wed, Apr 16, 2014 at 10:21 AM, Ed D'Azevedo <dazevedoef at ornl.gov> wrote:
> Hi Mark,
> I got an error when I tried the simple test code (see attached) on Titan.
> Can you try to run the attached test case to see if it will work for you?
> I have also sent the simple test code to Barry.
> The code seems to work with 1 thread
> env003> export OMP_NUM_THREADS=1
> env003> aprun -n 1 -d 16 ./tpetsc_madams
>  PETSC_VERSION_RELEASE               0
>  PETSC_VERSION_MAJOR                 3
>  PETSC_VERSION_MINOR                 4
>  PETSC_VERSION_SUBMINOR              4
>  PETSC_VERSION_PATCH                 0
>  PETSC_VERSION_DATE      unknown
>  petsc_version_lt(3,3,0) is false
>  nthreads =             1  NCASES =           100
>  nz =         88804
> Warning: ieee_inexact is signaling
> all done
>  total time is     7.268438
>  maxval(err)    6.9650285539069046E-011
> Application 4895013 resources: utime ~8s, stime ~0s, Rss ~22300, inblocks
> ~11428, outblocks ~35848
> The code seems to have trouble using more threads
> env003> export OMP_NUM_THREADS=16
> *** glibc detected *** ./tpetsc_madams: double free or corruption (!prev):
> 0x00000000015ee0b0 ***
>  nthreads =            16  NCASES =           100
> tpetsc_madams: malloc.c:3091: sYSMALLOc: Assertion `(old_top ==
> (((mbinptr) (((char *) &((av)->bins[((1) - 1) * 2])) - __builtin_offsetof
> (struct malloc_chunk, fd)))) && old_size == 0) || ((unsigned long)
> (old_size) >= (unsigned long)((((__builtin_offsetof (struct malloc_chunk,
> fd_nextsize))+((2 * (sizeof(size_t))) - 1)) & ~((2 * (sizeof(size_t))) -
> 1))) && ((old_top)->size & 0x1) && ((unsigned long)old_end & pagemask) ==
> 0)' failed.
> Error: abort
>    rax 0000000000000000, rbx 0000000000000fff, rcx ffffffffffffffff
>    rdx 0000000000000006, rsp 00002aaac4554f78, rbp 00002aaad0000098
>    rsi 0000000000005200, rdi 00000000000051f1, r8  00000000ffffffff
>    r9  00002aaaba8f9e40, r10 0000000000000008, r11 0000000000000202
>    r12 0000000000000000, r13 00002aaad0008e30, r14 0000000000000020
>    r15 0000000000000000
> ======= Backtrace: =========
> /lib64/libc.so.6(+0x75558)[0x2aaaba5ff558]
> /lib64/libc.so.6(cfree+0x6c)[0x2aaaba6044fc]
> ./tpetsc_madams[0x4b7759]
>   /lib64/libpthread.so.0(+0xf7c0) [0x2aaaaacdb7c0]
>   /lib64/libc.so.6(gsignal+0x35) [0x2aaaba5bcb55]
>   /lib64/libc.so.6(abort+0x181) [0x2aaaba5be131]
>   /lib64/libc.so.6(+0x7576d) [0x2aaaba5ff76d]
>   /lib64/libc.so.6(+0x789f0) [0x2aaaba6029f0]
>   /lib64/libc.so.6(__libc_malloc+0x77) [0x2aaaba6045e7]
>   ./tpetsc_madams() [0x4b76e3]
>   ./tpetsc_madams() [0x4aa3d7]
>   ./tpetsc_madams() [0x484888]
>   ./tpetsc_madams() [0x475798]
>   ./tpetsc_madams() [0x548aa5]
>   ./tpetsc_madams() [0x5e5df2]
>   ./tpetsc_madams() [0x57a353]
>   ./tpetsc_madams() [0x4a701e]
>   ./tpetsc_madams() [0x44e9be]
>   ./tpetsc_madams() [0x44e1f4]
>   /lib64/libc.so.6(__libc_start_main+0xe6) [0x2aaaba5a8c36]
>   ./tpetsc_madams() [0x44e0e9]
> Application 4895021 exit codes: 127
> Application 4895021 resources: utime ~0s, stime ~0s, Rss ~12544, inblocks
> ~11429, outblocks ~35849
> On 04/11/2014 04:34 PM, Mark Adams wrote:
> PETSc dev 'master' now has Barry's thread safe stuff so you should be able
> to use that.  I have build it in:
>  PETSC_DIR=/autofs/na3_home1/adams/petsc
> PETSC_ARCH=arch-titan-opt
>  So try this version out.  And revert the code to the repo version by
> doing:
>  > git checkout poisson.F90
>  and any other place where #if PETSC_VERSION_GE(3,5,0) is used.  I only
> see poisson.F90.
>  If this works I can install it wherever you like as Ed did.
>  Mark
>  On Thu, Apr 10, 2014 at 11:24 PM, Seung-Hoe Ku <sku at pppl.gov> wrote:
>>   Hi Mark,
>> I think it is not a big problem until we use petsc 3.5 other than you.
>> Now I disabled #if #endif for other users. Sorry for the inconvenience.
>> Could you uncomment it when you are working with 3.5, and does not commit
>> to core_dev, please?
>>  We need Ed's thread safe petsc for performance issue, so we can find
>> some way to resolve it when 3.5 is released and installed on titan.
>>  Thanks,
>>  Seung-Hoe
>> On Thu, Apr 10, 2014 at 11:38 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>> We've figured out the problem (again).  It will be fixed in future
>>> versions.
>>>  We can fix your installation.  I'm guessing Ed did this installation
>>> so it might not be worth fixing this code since you are up and running.
>>>  Let me know what you want to do.
>>>  The problem is that is a development version of the code, which is not
>>> as stable as the releases.  This version needs to be updated to get fix
>>> this problem.  I have to tell you how to do this update so let me know if
>>> you want to do it.
>>>  Mark
>>> On Thu, Apr 10, 2014 at 8:58 AM, Seung-Hoe Ku <sku at pppl.gov> wrote:
>>>>  One question is..
>>>>  If PETSC_VERSION_GE is defined with PETSC_VERSION_GT and
>>>> PETSC_VERSION_GT is defined with something in petsc.h,
>>>>  redefinition of PETSC_VERSION_GT after petsc.h will change
>>>> PETSC_VERSION_GE?
>>>> On Thu, Apr 10, 2014 at 10:55 AM, Seung-Hoe Ku <sku at pppl.gov> wrote:
>>>>> This is the code I tried to compile.
>>>>> #if PETSC_VERSION_GE(5,5,0)
>>>>>  214   BBBBBBBBBBBBBBBBBBB=0
>>>>>  215   call KSPSetOperators(solver%ksp,  solver%Amat,  solver%Amat,
>>>>> ierr )
>>>>>  216 #else
>>>>>  217   AAAAAAAAAAAA=0
>>>>>  218   call KSPSetOperators(solver%ksp,  solver%Amat,  solver%Amat,
>>>>> SAME_NONZERO_PATT     ERN, ierr )
>>>>>  219 #endif
>>>>>  On Thu, Apr 10, 2014 at 10:49 AM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>  On Thu, Apr 10, 2014 at 8:25 AM, Seung-Hoe Ku <sku at pppl.gov> wrote:
>>>>>>>    I have the same problem. I used poisson.F90 in
>>>>>>> /lustre/atlas2/env003/scratch/shku/XGC1_3_petsc_problem/
>>>>>>>  It seems that #undef should be after #include<finclude/petsc.h>.
>>>>>>> Otherwise, petsc.h seems to try redefine it.
>>>>>>  Oh yes.
>>>>>>>   Anyway, I got the same error message:
>>>>>>> PGF90-S-0038-Symbol, bbbbbbbbbbbbbbbbbbb, has not been explicitly
>>>>>>> declared (poisson.F90)
>>>>>>>   0 inform,   0 warnings,   1 severes, 0 fatal for init_1field_solver
>>>>>>  is this in the source file?
>>>>>>>     I tried 5.5.0 for the arguments of PETSC_VERSION_GE, but still
>>>>>>>  Or do you mean VERSION_GE and VERSION_LT instead of VERSION_GT and
>>>>>>> VERSION_LE?
>>>>>>>  Thanks,
>>>>>>>  Seung-Hoe
>>>>>>> On Wed, Apr 9, 2014 at 9:54 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>>>>>>> We might have a fix.  It turns out that some fortran compilers to
>>>>>>>> not do the #define quite right. Try this:
>>>>>>>>  This will out the original (bad) file back. Then add to
>>>>>>>> poisson.F90
>>>>>>>>  #undef PETSC_VERSION_GT
>>>>>>>>  #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
>>>>>>>>   (0==PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR))
>>>>>>>>   This is the fix that Jed thinks will work.  If it works we can
>>>>>>>> propagate it.
>>>>>>>>  Sorry about the confusion,
>>>>>>>> Mark
>>>>>>>> On Wed, Apr 9, 2014 at 7:36 PM, Seung-Hoe Ku <sku at pppl.gov> wrote:
>>>>>>>>> Great! Thank you.
>>>>>>>>>  On Wed, Apr 9, 2014 at 9:35 PM, Mark Adams <mfadams at lbl.gov>wrote:
>>>>>>>>>> Good news.  I'm at a meeting and Jed Brown is here and he seems
>>>>>>>>>> to have been able to reproduce the error.  Preprocessors can be a pain.
>>>>>>>>>>  I'm going to wait until Jed has a chance to look at this and come up with
>>>>>>>>>> a solution.
>>>>>>>>>> On Wed, Apr 9, 2014 at 7:28 PM, Seung-Hoe Ku <sku at pppl.gov>wrote:
>>>>>>>>>>>  Now I am using iterative solver which will be replaced to your
>>>>>>>>>>> 2 field solver later.
>>>>>>>>>>> Sorry. The line number 3003 is wrong. It is  209 or near it.
>>>>>>>>>>>  Yes. We can take a look at this when you come. It is not
>>>>>>>>>>> urgent problem.
>>>>>>>>>>>  Thanks,
>>>>>>>>>>> Seung-Hoe
>>>>>>>>>>> On Wed, Apr 9, 2014 at 9:25 PM, Mark Adams <mfadams at lbl.gov>wrote:
>>>>>>>>>>>> I noticed that your makefile was not using the new petsc
>>>>>>>>>>>> solver.  Is that intensional?
>>>>>>>>>>>>  The line you gave me 3003 poission.F90 seems to be the last
>>>>>>>>>>>> line of the file.
>>>>>>>>>>>>  I am not getting Edison or Titan to build.  We can take a
>>>>>>>>>>>> look at this next week.
>>>>>>>>>>>>  Mark
>>>>>>>>>>>> On Tue, Apr 8, 2014 at 12:38 PM, Seung-Hoe Ku <sku at pppl.gov>wrote:
>>>>>>>>>>>>>  Hi Mark,
>>>>>>>>>>>>>  It seems that PETSC_VERSION_GE is not working line 3003 of
>>>>>>>>>>>>> poisson.F90. Is there any reason of using PETSC_VERSION_GE instead of
>>>>>>>>>>>>> PETSC_VERSION_LE? The previous code worked, I think.
>>>>>>>>>>>>>  Thanks,
>>>>>>>>>>>>> Seung-Hoe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140416/071b41bd/attachment.html>
