[petsc-dev] calling DMPlexPointLocalRef() from fortran
Adrian Croucher a.croucher at auckland.ac.nz
Tue Apr 8 00:18:57 CDT 2014
On 08/04/14 06:52, Matthew Knepley wrote:
> I got your code running. There were a few code problems (fixed in my
> attached version), but the
> problem you are seeing above is a bug in our system for generating
> Fortran wrappers. The fix
> will be pushed out soon, but I am attaching dmf.c which you can put in
> src/dm/interface/ftn-auto
> and rebuild and things should work for you.
Thanks very much. That did fix the error I was getting yesterday (once I
also removed the call to DMSetPointSF()).
Next I am trying to visualize the partition vector via VTK, using the
subroutine below (again modelled on what is done in TS ex 33):
subroutine VTK_output(filename, v)
   ! Writes the vector v to a VTK file
   implicit none
#include <finclude/petsc.h90>
   character(*), intent(in) :: filename
   Vec, intent(in) :: v
   ! Locals:
   PetscErrorCode :: ierr
   PetscViewer :: viewer
   call PetscViewerCreate(PETSC_COMM_WORLD, viewer, ierr); CHKERRQ(ierr)
   call PetscViewerSetType(viewer, PETSCVIEWERVTK, ierr); CHKERRQ(ierr)
   call PetscViewerFileSetName(viewer, filename, ierr); CHKERRQ(ierr)
   call VecView(v, viewer, ierr); CHKERRQ(ierr)
   call PetscViewerDestroy(viewer, ierr); CHKERRQ(ierr)
end subroutine VTK_output
However it crashes with this error message:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Null argument, when expecting valid pointer
[0]PETSC ERROR: Null Object: Parameter # 1
[0]PETSC ERROR: See
http://http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
shooting.
[0]PETSC ERROR: Petsc Development GIT revision: v3.4.4-5339-g8a3122f
GIT Date: 2014-04-07 17:35:29 -0500
[0]PETSC ERROR: testplex on a linux-gnu-c-opt named des108 by acro018
Tue Apr  8 17:12:35 2014
[0]PETSC ERROR: Configure options --download-netcdf --download-exodusii
--with-hdf5-dir=/usr/lib --with-numpy-dir=/usr/lib/pymodul
es/python2.7/numpy
--with-scientificpython-dir=/usr/lib/python2.7/dist-packages/scipy
--with-petsc4py-dir=/usr/local/lib/python2.7
/dist-packages/petsc4py --download-triangle --with-fortran-interfaces=1
--download-ptscotch --download-chaco --download-ctetgen
[0]PETSC ERROR: #1 VecGetDM() line 200 in
/home/acro018/software/PETSc/code/src/dm/interface/dm.c
[0]PETSC ERROR: #2 DMPlexInsertBoundaryValuesFVM() line 403 in
/home/acro018/software/PETSc/code/src/dm/impls/plex/plexfem.c
[0]PETSC ERROR: #3 VecView_Plex_Local() line 235 in
/home/acro018/software/PETSc/code/src/dm/impls/plex/plex.c
[0]PETSC ERROR: #4 VecView() line 666 in
/home/acro018/software/PETSc/code/src/vec/vec/interface/vector.c
Would this be expected to work in fortran at the moment? Or have I just
messed it up?
I also came across another function that seems to be lacking a fortran
interface: DMPlexConstructGhostCells(). Not totally sure if I need that,
but again was just trying to follow what is done in TS ex 33.
Cheers, Adrian
Dr Adrian Croucher
Department of Engineering Science
University of Auckland
New Zealand
tel 64-9-373-7599 ext 84611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140408/d3a05e0b/attachment.html>
