[petsc-dev] calling DMPlexPointLocalRef() from fortran
Mon Apr 7 13:52:43 CDT 2014
On Mon, Apr 7, 2014 at 12:05 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Apr 6, 2014 at 9:43 PM, Adrian Croucher <a.croucher at auckland.ac.nz
> > wrote:
>> On 05/04/14 02:31, Matthew Knepley wrote:
>> Instead of this, use
>>    call DMPlexGetDefaultSection(cell_dm, section, ierr); (Move outside
>> of loop)
>>   call PetscSectionGetOffset(section, c, off, ierr);
>>   part(off) =rank
>> OK thanks. The code compiles now.
>> However, at runtime I'm getting another error, when it calls
>> DMSetPointSF():
>> [0]PETSC ERROR: #1 DMSetPointSF() line 3204 in
>> /home/acro018/software/PETSc/code/src/dm/interface/dm.c
>> [1]PETSC ERROR: --------------------- Error Message
>> [1]PETSC ERROR: Invalid argument
>> [1]PETSC ERROR: Wrong type of object: Parameter # 1
>> [1]PETSC ERROR: See
>> http://http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>> shooting.
>> [1]PETSC ERROR: Petsc Development GIT revision: v3.4.4-5306-g9849faf  GIT
>> Date: 2014-04-06 15:35:41 -0500
>> This seems to work fine in C, so I'm wondering if I need to do something
>> different in fortran, or if the interface isn't quite working right. My
>> test code is below. The offending call to DMSetPointSF() is in the routine
>> create_partition_vector(). Any tips much appreciated!
> 1) You do not need those calls since DMClone() now does this automatically.
> 2) However, it looks like DMClone() is not functioning correctly for you
> since cell_dm should be alright.
> I will try and run your code today.
I got your code running. There were a few code problems (fixed in my
attached version), but the
problem you are seeing above is a bug in our system for generating Fortran
wrappers. The fix
will be pushed out soon, but I am attaching dmf.c which you can put in
src/dm/interface/ftn-auto
and rebuild and things should work for you.
     Matt
> It also occurred to me there might just be something wrong with my mesh,
>> so I also tested it using a mesh created with DMPLexCreateBoxMesh()- but
>> this gave the same error (and also indicated that the fortran interface to
>> DMPlexSetRefinementLimit() is probably also missing in action!).
> Fixed. Will push it today.
>   Thanks,
>      Matt
>>  - Adrian
>> program testplex
>>   ! Testing PETSc dmplex from fortran, using a line of blocks in 3-D.
>>   ! Create the DMPlex by passing in the cell definitions to
>> DMPlexCreateFromDAG(),
>>   ! interpolate the result to form the faces and edges, distribute over
>> the
>>   ! processors, and visualize the partitions in VTK.
>>   implicit none
>> #include <finclude/petsc.h90>
>>   PetscInt, parameter  :: num_cells = 20
>>   PetscReal, parameter :: cell_size = 10.
>>   PetscErrorCode :: ierr
>>   DM :: dm, dist_dm, cell_dm
>>   character(5) :: partitioner = "chaco"
>>   PetscInt :: overlap = 0
>>   Vec :: partition
>>   call PetscInitialize(PETSC_NULL_CHARACTER, ierr); CHKERRQ(ierr)
>>   call create_1d_grid(num_cells, cell_size, dm, ierr); CHKERRQ(ierr)
>>   call DMPlexDistribute(dm, partitioner, overlap, PETSC_NULL_OBJECT,
>> dist_dm, ierr)
>>   CHKERRQ(ierr)
>>   call DMDestroy(dm, ierr); CHKERRQ(ierr)
>>   dm = dist_dm
>>   call DMView(dm, PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr)
>>   call create_partition_vector(dm, cell_dm, partition, ierr);
>> CHKERRQ(ierr)
>>   ! Visualize partition vector here...
>>   call PetscFinalize(ierr); CHKERRQ(ierr)
>> end program testplex
>> subroutine create_1d_grid(num_cells, cell_size, dm, ierr)
>>   ! Creates grid consisting of a 1D line of cube cells in 3D.
>>   implicit none
>>   PetscInt, intent(in) :: num_cells
>>   PetscReal, intent(in):: cell_size
>>   DM, intent(out) :: dm
>>   PetscErrorCode, intent(out) :: ierr
>>   ! Locals:
>>   PetscInt, parameter :: dim = 3
>>   PetscMPIInt :: rank
>>   PetscInt  :: num_vertices_per_face, num_vertices_per_cell
>>   PetscInt  :: num_vertices, total_num_points
>>   PetscInt  :: i, i0, i1, l
>>   PetscInt  :: depth
>>   real(8)   :: x0, dx
>>   PetscInt, allocatable :: num_points(:)
>>   PetscInt, allocatable :: cone_size(:)
>>   PetscInt, allocatable :: cones(:)
>>   PetscInt, allocatable :: cone_orientations(:)
>>   PetscScalar, allocatable :: vertex_coords(:)
>>   DM :: interp_dm
>>   ierr = 0
>>   call MPI_Comm_rank(PETSC_COMM_WORLD, rank, ierr); CHKERRQ(ierr)
>>   call DMPlexCreate(PETSC_COMM_WORLD, dm, ierr); CHKERRQ(ierr)
>>   call PetscObjectSetName(dm, "testplex", ierr); CHKERRQ(ierr)
>>   call DMPlexSetDimension(dm, dim, ierr); CHKERRQ(ierr)
>>   if (rank == 0) then
>>      num_vertices_per_face = 2 ** (dim-1)
>>      num_vertices_per_cell = 2 * num_vertices_per_face
>>      num_vertices = num_vertices_per_face * (num_cells + 1)
>>      l = num_vertices_per_face * dim
>>      total_num_points = num_vertices + num_cells ! # points in DAG
>>      allocate(vertex_coords(0:num_vertices*dim-1),
>> cones(0:num_cells*num_vertices_per_cell-1))
>>      ! Set up vertex coordinates
>>      dx = real(cell_size)
>>      do i = 0, num_cells
>>         i0 = i * l
>>         i1 = (i+1)*l
>>         x0 = real(i * cell_size)
>>         vertex_coords(i0:i1) = \
>>         [x0, 0.d0, 0.d0,\
>>         x0, dx, 0.d0,\
>>         x0, 0.d0, dx,\
>>         x0, dx, dx]
>>      end do
>>      ! Set up cells
>>      do i = 0, num_cells-1
>>         i0 = i * num_vertices_per_cell
>>         i1 = (i+1) * num_vertices_per_cell
>>         cones(i0:i1) = [0, 1, 5, 4, 2, 6, 7, 3] + i *
>>      end do
>>      cones = cones + num_cells
>>      num_points = [num_vertices, num_cells]
>>      allocate(cone_size(0: total_num_points-1))
>>      allocate(cone_orientations(0:num_cells*num_vertices_per_cell-1))
>>      cone_size = 0
>>      cone_size(0: num_cells-1) = num_vertices_per_cell
>>      cone_orientations = 0
>>      depth = 1
>>      call DMPlexCreateFromDAG(dm, depth, num_points, cone_size, cones, &
>>           cone_orientations, vertex_coords, ierr); CHKERRQ(ierr)
>>   else ! rank > 0: create empty DMPlex
>>      num_points = [0, 0, 0]; cone_size = [0]
>>      cones = [0]; cone_orientations = [0]
>>      vertex_coords = [0]
>>      call DMPlexCreateFromDAG(dm, 1, num_points, cone_size, &
>>           cones, cone_orientations, vertex_coords, ierr); CHKERRQ(ierr)
>>   end if
>>   interp_dm = PETSC_NULL_OBJECT
>>   call DMPlexInterpolate(dm, interp_dm, ierr); CHKERRQ(ierr)
>>   call DMPlexCopyCoordinates(dm, interp_dm, ierr); CHKERRQ(ierr)
>>   dm = interp_dm
>>   deallocate(num_points, cone_size, cones, cone_orientations,
>> vertex_coords)
>> end subroutine create_1d_grid
>> subroutine create_partition_vector(dm, cell_dm, partition, ierr)
>>   ! Returns a DM and vector containing partitioning data
>>   implicit none
>>   DM, intent(in) :: dm
>>   DM, intent(out) :: cell_dm
>>   Vec, intent(out) :: partition
>>   ! Locals:
>>   MPI_Comm :: comm
>>   PetscMPIInt :: rank
>>   PetscSF :: sfPoint
>>   PetscSection :: coord_section
>>   Vec :: coordinates
>>   PetscSection :: cell_section
>>   PetscScalar, pointer :: part(:)
>>   PetscInt :: cStart, cEnd, c, off
>>   call DMGetCoordinateSection(dm, coord_section, ierr); CHKERRQ(ierr)
>>   call DMGetCoordinatesLocal(dm, coordinates, ierr); CHKERRQ(ierr)
>>   call DMClone(dm, cell_dm, ierr); CHKERRQ(ierr)
>>   call DMGetPointSF(dm, sfPoint, ierr); CHKERRQ(ierr)
>>   call DMSetPointSF(cell_dm, sfPoint, ierr); CHKERRQ(ierr)
>>   call DMSetCoordinateSection(cell_dm, coord_section, ierr); CHKERRQ(ierr)
>>   call DMSetCoordinatesLocal(cell_dm, coordinates, ierr); CHKERRQ(ierr)
>>   call PetscObjectGetComm(dm, comm, ierr); CHKERRQ(ierr)
>>   call PetscSectionCreate(comm, cell_section, ierr); CHKERRQ(ierr)
>>   call DMPlexGetHeightStratum(cell_dm, 0, cStart, cEnd, ierr);
>> CHKERRQ(ierr)
>>   call PetscSectionSetChart(cell_section, cStart, cEnd, ierr);
>> CHKERRQ(ierr)
>>   do c = cStart, cEnd-1
>>      call PetscSectionSetDof(cell_section, c, 1, ierr); CHKERRQ(ierr)
>>   end do
>>   call PetscSectionSetUp(cell_section, ierr); CHKERRQ(ierr)
>>   call DMSetDefaultSection(cell_dm, cell_section, ierr); CHKERRQ(ierr)
>>   call PetscSectionDestroy(cell_section, ierr); CHKERRQ(ierr)
>>   call DMCreateLocalVector(cell_dm, partition, ierr); CHKERRQ(ierr)
>>   call PetscObjectSetName(partition, "partition", ierr); CHKERRQ(ierr)
>>   call VecGetArrayF90(partition, part, ierr); CHKERRQ(ierr)
>>   call MPI_Comm_rank(comm, rank); CHKERRQ(ierr)
>>      call PetscSectionGetOffset(cell_section, c, off, ierr); CHKERRQ(ierr)
>>      part(off) = rank
>>   end do
>>   call VecRestoreArrayF90(partition, part, ierr); CHKERRQ(ierr)
>> end subroutine create_partition_vector
>> Dr Adrian Croucher
>> Department of Engineering Science
>> University of Auckland
>> New Zealand
>> tel 64-9-373-7599 ext 84611
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140407/c224f6da/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140407/c224f6da/attachment.obj>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140407/c224f6da/attachment.bin>
