[petsc-dev] calling DMPlexPointLocalRef() from fortran
Tue Apr 8 06:31:08 CDT 2014
On Tue, Apr 8, 2014 at 12:18 AM, Adrian Croucher
<a.croucher at auckland.ac.nz>wrote:
> On 08/04/14 06:52, Matthew Knepley wrote:
>  I got your code running. There were a few code problems (fixed in my
> attached version), but the
> problem you are seeing above is a bug in our system for generating Fortran
> wrappers. The fix
> will be pushed out soon, but I am attaching dmf.c which you can put in
> src/dm/interface/ftn-auto
> and rebuild and things should work for you.
> Thanks very much. That did fix the error I was getting yesterday (once I
> also removed the call to DMSetPointSF()).
> Next I am trying to visualize the partition vector via VTK, using the
> subroutine below (again modelled on what is done in TS ex 33):
1) ex33 will probably get eliminated. It is mostly a copy of ex11 which
does work. Use that.
2) Are you solving something using FVM?
3) The VTK/HDF5 output now relies on being able to set the boundary values
automatically. Here is it trying
     to do it for FVM. Right now, it assumes that you have told it about
the face geometry, which happens in ex11.
    If you do not want this, I need to understand what you want to do.
  Matt
> subroutine VTK_output(filename, v)
>   ! Writes the vector v to a VTK file
>   implicit none
> #include <finclude/petsc.h90>
>   character(*), intent(in) :: filename
>   Vec, intent(in) :: v
>   ! Locals:
>   PetscErrorCode :: ierr
>   PetscViewer :: viewer
>   call PetscViewerCreate(PETSC_COMM_WORLD, viewer, ierr); CHKERRQ(ierr)
>   call PetscViewerSetType(viewer, PETSCVIEWERVTK, ierr); CHKERRQ(ierr)
>   call PetscViewerFileSetName(viewer, filename, ierr); CHKERRQ(ierr)
>   call VecView(v, viewer, ierr); CHKERRQ(ierr)
>   call PetscViewerDestroy(viewer, ierr); CHKERRQ(ierr)
> end subroutine VTK_output
> However it crashes with this error message:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Null argument, when expecting valid pointer
> [0]PETSC ERROR: Null Object: Parameter # 1
> [0]PETSC ERROR: See
> http://http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> shooting.
> [0]PETSC ERROR: Petsc Development GIT revision: v3.4.4-5339-g8a3122f  GIT
> Date: 2014-04-07 17:35:29 -0500
> [0]PETSC ERROR: testplex on a linux-gnu-c-opt named des108 by acro018 Tue
> Apr  8 17:12:35 2014
> [0]PETSC ERROR: Configure options --download-netcdf --download-exodusii
> --with-hdf5-dir=/usr/lib --with-numpy-dir=/usr/lib/pymodul
> es/python2.7/numpy
> --with-scientificpython-dir=/usr/lib/python2.7/dist-packages/scipy
> --with-petsc4py-dir=/usr/local/lib/python2.7
> /dist-packages/petsc4py --download-triangle --with-fortran-interfaces=1
> --download-ptscotch --download-chaco --download-ctetgen
> [0]PETSC ERROR: #1 VecGetDM() line 200 in
> /home/acro018/software/PETSc/code/src/dm/interface/dm.c
> [0]PETSC ERROR: #2 DMPlexInsertBoundaryValuesFVM() line 403 in
> /home/acro018/software/PETSc/code/src/dm/impls/plex/plexfem.c
> [0]PETSC ERROR: #3 VecView_Plex_Local() line 235 in
> /home/acro018/software/PETSc/code/src/dm/impls/plex/plex.c
> [0]PETSC ERROR: #4 VecView() line 666 in
> /home/acro018/software/PETSc/code/src/vec/vec/interface/vector.c
> Would this be expected to work in fortran at the moment? Or have I just
> messed it up?
> I also came across another function that seems to be lacking a fortran
> interface: DMPlexConstructGhostCells(). Not totally sure if I need that,
> but again was just trying to follow what is done in TS ex 33.
> Cheers, Adrian
> Dr Adrian Croucher
> Department of Engineering Science
> University of Auckland
> New Zealand
> tel 64-9-373-7599 ext 84611
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140408/1c0feb65/attachment.html>
