[petsc-dev] calling DMPlexPointLocalRef() from fortran
Mon Apr 7 12:05:16 CDT 2014
On Sun, Apr 6, 2014 at 9:43 PM, Adrian Croucher
<a.croucher at auckland.ac.nz>wrote:
> On 05/04/14 02:31, Matthew Knepley wrote:
> Instead of this, use
>    call DMPlexGetDefaultSection(cell_dm, section, ierr); (Move outside of
> loop)
>   call PetscSectionGetOffset(section, c, off, ierr);
>   part(off) =rank
> OK thanks. The code compiles now.
> However, at runtime I'm getting another error, when it calls
> DMSetPointSF():
> [0]PETSC ERROR: #1 DMSetPointSF() line 3204 in
> /home/acro018/software/PETSc/code/src/dm/interface/dm.c
> [1]PETSC ERROR: --------------------- Error Message
> [1]PETSC ERROR: Invalid argument
> [1]PETSC ERROR: Wrong type of object: Parameter # 1
> [1]PETSC ERROR: See
> http://http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
> shooting.
> [1]PETSC ERROR: Petsc Development GIT revision: v3.4.4-5306-g9849faf  GIT
> Date: 2014-04-06 15:35:41 -0500
> This seems to work fine in C, so I'm wondering if I need to do something
> different in fortran, or if the interface isn't quite working right. My
> test code is below. The offending call to DMSetPointSF() is in the routine
> create_partition_vector(). Any tips much appreciated!
1) You do not need those calls since DMClone() now does this automatically.
2) However, it looks like DMClone() is not functioning correctly for you
since cell_dm should be alright.
I will try and run your code today.
It also occurred to me there might just be something wrong with my mesh, so
> I also tested it using a mesh created with DMPLexCreateBoxMesh()- but this
> gave the same error (and also indicated that the fortran interface to
> DMPlexSetRefinementLimit() is probably also missing in action!).
Fixed. Will push it today.
     Matt
> - Adrian
> program testplex
>   ! Testing PETSc dmplex from fortran, using a line of blocks in 3-D.
>   ! Create the DMPlex by passing in the cell definitions to
> DMPlexCreateFromDAG(),
>   ! interpolate the result to form the faces and edges, distribute over the
>   ! processors, and visualize the partitions in VTK.
>   implicit none
> #include <finclude/petsc.h90>
>   PetscInt, parameter  :: num_cells = 20
>   PetscReal, parameter :: cell_size = 10.
>   PetscErrorCode :: ierr
>   DM :: dm, dist_dm, cell_dm
>   character(5) :: partitioner = "chaco"
>   PetscInt :: overlap = 0
>   Vec :: partition
>   call PetscInitialize(PETSC_NULL_CHARACTER, ierr); CHKERRQ(ierr)
>   call create_1d_grid(num_cells, cell_size, dm, ierr); CHKERRQ(ierr)
>   call DMPlexDistribute(dm, partitioner, overlap, PETSC_NULL_OBJECT,
> dist_dm, ierr)
>   CHKERRQ(ierr)
>   call DMDestroy(dm, ierr); CHKERRQ(ierr)
>   dm = dist_dm
>   call DMView(dm, PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr)
>   call create_partition_vector(dm, cell_dm, partition, ierr); CHKERRQ(ierr)
>   ! Visualize partition vector here...
>   call PetscFinalize(ierr); CHKERRQ(ierr)
> end program testplex
> subroutine create_1d_grid(num_cells, cell_size, dm, ierr)
>   ! Creates grid consisting of a 1D line of cube cells in 3D.
>   implicit none
>   PetscInt, intent(in) :: num_cells
>   PetscReal, intent(in):: cell_size
>   DM, intent(out) :: dm
>   PetscErrorCode, intent(out) :: ierr
>   ! Locals:
>   PetscInt, parameter :: dim = 3
>   PetscMPIInt :: rank
>   PetscInt  :: num_vertices_per_face, num_vertices_per_cell
>   PetscInt  :: num_vertices, total_num_points
>   PetscInt  :: i, i0, i1, l
>   PetscInt  :: depth
>   real(8)   :: x0, dx
>   PetscInt, allocatable :: num_points(:)
>   PetscInt, allocatable :: cone_size(:)
>   PetscInt, allocatable :: cones(:)
>   PetscInt, allocatable :: cone_orientations(:)
>   PetscScalar, allocatable :: vertex_coords(:)
>   DM :: interp_dm
>   ierr = 0
>   call MPI_Comm_rank(PETSC_COMM_WORLD, rank, ierr); CHKERRQ(ierr)
>   call DMPlexCreate(PETSC_COMM_WORLD, dm, ierr); CHKERRQ(ierr)
>   call PetscObjectSetName(dm, "testplex", ierr); CHKERRQ(ierr)
>   call DMPlexSetDimension(dm, dim, ierr); CHKERRQ(ierr)
>   if (rank == 0) then
>      num_vertices_per_face = 2 ** (dim-1)
>      num_vertices_per_cell = 2 * num_vertices_per_face
>      num_vertices = num_vertices_per_face * (num_cells + 1)
>      l = num_vertices_per_face * dim
>      total_num_points = num_vertices + num_cells ! # points in DAG
>      allocate(vertex_coords(0:num_vertices*dim-1),
> cones(0:num_cells*num_vertices_per_cell-1))
>      ! Set up vertex coordinates
>      dx = real(cell_size)
>      do i = 0, num_cells
>         i0 = i * l
>         i1 = (i+1)*l
>         x0 = real(i * cell_size)
>         vertex_coords(i0:i1) = \
>         [x0, 0.d0, 0.d0,\
>         x0, dx, 0.d0,\
>         x0, 0.d0, dx,\
>         x0, dx, dx]
>      end do
>      ! Set up cells
>      do i = 0, num_cells-1
>         i0 = i * num_vertices_per_cell
>         i1 = (i+1) * num_vertices_per_cell
>         cones(i0:i1) = [0, 1, 5, 4, 2, 6, 7, 3] + i *
>      end do
>      cones = cones + num_cells
>      num_points = [num_vertices, num_cells]
>      allocate(cone_size(0: total_num_points-1))
>      allocate(cone_orientations(0:num_cells*num_vertices_per_cell-1))
>      cone_size = 0
>      cone_size(0: num_cells-1) = num_vertices_per_cell
>      cone_orientations = 0
>      depth = 1
>      call DMPlexCreateFromDAG(dm, depth, num_points, cone_size, cones, &
>           cone_orientations, vertex_coords, ierr); CHKERRQ(ierr)
>   else ! rank > 0: create empty DMPlex
>      num_points = [0, 0, 0]; cone_size = [0]
>      cones = [0]; cone_orientations = [0]
>      vertex_coords = [0]
>      call DMPlexCreateFromDAG(dm, 1, num_points, cone_size, &
>           cones, cone_orientations, vertex_coords, ierr); CHKERRQ(ierr)
>   end if
>   interp_dm = PETSC_NULL_OBJECT
>   call DMPlexInterpolate(dm, interp_dm, ierr); CHKERRQ(ierr)
>   call DMPlexCopyCoordinates(dm, interp_dm, ierr); CHKERRQ(ierr)
>   dm = interp_dm
>   deallocate(num_points, cone_size, cones, cone_orientations,
> vertex_coords)
> end subroutine create_1d_grid
> subroutine create_partition_vector(dm, cell_dm, partition, ierr)
>   ! Returns a DM and vector containing partitioning data
>   implicit none
>   DM, intent(in) :: dm
>   DM, intent(out) :: cell_dm
>   Vec, intent(out) :: partition
>   ! Locals:
>   MPI_Comm :: comm
>   PetscMPIInt :: rank
>   PetscSF :: sfPoint
>   PetscSection :: coord_section
>   Vec :: coordinates
>   PetscSection :: cell_section
>   PetscScalar, pointer :: part(:)
>   PetscInt :: cStart, cEnd, c, off
>   call DMGetCoordinateSection(dm, coord_section, ierr); CHKERRQ(ierr)
>   call DMGetCoordinatesLocal(dm, coordinates, ierr); CHKERRQ(ierr)
>   call DMClone(dm, cell_dm, ierr); CHKERRQ(ierr)
>   call DMGetPointSF(dm, sfPoint, ierr); CHKERRQ(ierr)
>   call DMSetPointSF(cell_dm, sfPoint, ierr); CHKERRQ(ierr)
>   call DMSetCoordinateSection(cell_dm, coord_section, ierr); CHKERRQ(ierr)
>   call DMSetCoordinatesLocal(cell_dm, coordinates, ierr); CHKERRQ(ierr)
>   call PetscObjectGetComm(dm, comm, ierr); CHKERRQ(ierr)
>   call PetscSectionCreate(comm, cell_section, ierr); CHKERRQ(ierr)
>   call DMPlexGetHeightStratum(cell_dm, 0, cStart, cEnd, ierr);
> CHKERRQ(ierr)
>   call PetscSectionSetChart(cell_section, cStart, cEnd, ierr);
> CHKERRQ(ierr)
>   do c = cStart, cEnd-1
>      call PetscSectionSetDof(cell_section, c, 1, ierr); CHKERRQ(ierr)
>   end do
>   call PetscSectionSetUp(cell_section, ierr); CHKERRQ(ierr)
>   call DMSetDefaultSection(cell_dm, cell_section, ierr); CHKERRQ(ierr)
>   call PetscSectionDestroy(cell_section, ierr); CHKERRQ(ierr)
>   call DMCreateLocalVector(cell_dm, partition, ierr); CHKERRQ(ierr)
>   call PetscObjectSetName(partition, "partition", ierr); CHKERRQ(ierr)
>   call VecGetArrayF90(partition, part, ierr); CHKERRQ(ierr)
>   call MPI_Comm_rank(comm, rank); CHKERRQ(ierr)
>      call PetscSectionGetOffset(cell_section, c, off, ierr); CHKERRQ(ierr)
>      part(off) = rank
>   end do
>   call VecRestoreArrayF90(partition, part, ierr); CHKERRQ(ierr)
> end subroutine create_partition_vector
> Dr Adrian Croucher
> Department of Engineering Science
> University of Auckland
> New Zealand
> tel 64-9-373-7599 ext 84611
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140407/02abaf93/attachment.html>
