[petsc-dev] calling DMPlexPointLocalRef() from fortran
Adrian Croucher a.croucher at auckland.ac.nz
Sun Apr 6 21:43:09 CDT 2014
On 05/04/14 02:31, Matthew Knepley wrote:
> Instead of this, use
>   call DMPlexGetDefaultSection(cell_dm, section, ierr); (Move outside
> of loop)
>   call PetscSectionGetOffset(section, c, off, ierr);
>   part(off) =rank
OK thanks. The code compiles now.
However, at runtime I'm getting another error, when it calls DMSetPointSF():
[0]PETSC ERROR: #1 DMSetPointSF() line 3204 in
/home/acro018/software/PETSc/code/src/dm/interface/dm.c
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Invalid argument
[1]PETSC ERROR: Wrong type of object: Parameter # 1
[1]PETSC ERROR: See
http://http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
shooting.
[1]PETSC ERROR: Petsc Development GIT revision: v3.4.4-5306-g9849faf
GIT Date: 2014-04-06 15:35:41 -0500
This seems to work fine in C, so I'm wondering if I need to do something
different in fortran, or if the interface isn't quite working right. My
test code is below. The offending call to DMSetPointSF() is in the
routine create_partition_vector(). Any tips much appreciated!
It also occurred to me there might just be something wrong with my mesh,
so I also tested it using a mesh created with DMPLexCreateBoxMesh()- but
this gave the same error (and also indicated that the fortran interface
to DMPlexSetRefinementLimit() is probably also missing in action!).
- Adrian
program testplex
   ! Testing PETSc dmplex from fortran, using a line of blocks in 3-D.
   ! Create the DMPlex by passing in the cell definitions to
DMPlexCreateFromDAG(),
   ! interpolate the result to form the faces and edges, distribute over the
   ! processors, and visualize the partitions in VTK.
   implicit none
#include <finclude/petsc.h90>
   PetscInt, parameter  :: num_cells = 20
   PetscReal, parameter :: cell_size = 10.
   PetscErrorCode :: ierr
   DM :: dm, dist_dm, cell_dm
   character(5) :: partitioner = "chaco"
   PetscInt :: overlap = 0
   Vec :: partition
   call PetscInitialize(PETSC_NULL_CHARACTER, ierr); CHKERRQ(ierr)
   call create_1d_grid(num_cells, cell_size, dm, ierr); CHKERRQ(ierr)
   call DMPlexDistribute(dm, partitioner, overlap, PETSC_NULL_OBJECT,
dist_dm, ierr)
   CHKERRQ(ierr)
   call DMDestroy(dm, ierr); CHKERRQ(ierr)
   dm = dist_dm
   call DMView(dm, PETSC_VIEWER_STDOUT_WORLD); CHKERRQ(ierr)
   call create_partition_vector(dm, cell_dm, partition, ierr); CHKERRQ(ierr)
   ! Visualize partition vector here...
   call PetscFinalize(ierr); CHKERRQ(ierr)
end program testplex
subroutine create_1d_grid(num_cells, cell_size, dm, ierr)
   ! Creates grid consisting of a 1D line of cube cells in 3D.
   implicit none
   PetscInt, intent(in) :: num_cells
   PetscReal, intent(in):: cell_size
   DM, intent(out) :: dm
   PetscErrorCode, intent(out) :: ierr
   ! Locals:
   PetscInt, parameter :: dim = 3
   PetscMPIInt :: rank
   PetscInt  :: num_vertices_per_face, num_vertices_per_cell
   PetscInt  :: num_vertices, total_num_points
   PetscInt  :: i, i0, i1, l
   PetscInt  :: depth
   real(8)   :: x0, dx
   PetscInt, allocatable :: num_points(:)
   PetscInt, allocatable :: cone_size(:)
   PetscInt, allocatable :: cones(:)
   PetscInt, allocatable :: cone_orientations(:)
   PetscScalar, allocatable :: vertex_coords(:)
   DM :: interp_dm
   ierr = 0
   call MPI_Comm_rank(PETSC_COMM_WORLD, rank, ierr); CHKERRQ(ierr)
   call DMPlexCreate(PETSC_COMM_WORLD, dm, ierr); CHKERRQ(ierr)
   call PetscObjectSetName(dm, "testplex", ierr); CHKERRQ(ierr)
   call DMPlexSetDimension(dm, dim, ierr); CHKERRQ(ierr)
   if (rank == 0) then
      num_vertices_per_face = 2 ** (dim-1)
      num_vertices_per_cell = 2 * num_vertices_per_face
      num_vertices = num_vertices_per_face * (num_cells + 1)
      l = num_vertices_per_face * dim
      total_num_points = num_vertices + num_cells ! # points in DAG
      allocate(vertex_coords(0:num_vertices*dim-1),
cones(0:num_cells*num_vertices_per_cell-1))
      ! Set up vertex coordinates
      dx = real(cell_size)
      do i = 0, num_cells
         i0 = i * l
         i1 = (i+1)*l
         x0 = real(i * cell_size)
         vertex_coords(i0:i1) = \
         [x0, 0.d0, 0.d0,\
         x0, dx, 0.d0,\
         x0, 0.d0, dx,\
         x0, dx, dx]
      end do
      ! Set up cells
      do i = 0, num_cells-1
         i0 = i * num_vertices_per_cell
         i1 = (i+1) * num_vertices_per_cell
         cones(i0:i1) = [0, 1, 5, 4, 2, 6, 7, 3] + i *
      end do
      cones = cones + num_cells
      num_points = [num_vertices, num_cells]
      allocate(cone_size(0: total_num_points-1))
allocate(cone_orientations(0:num_cells*num_vertices_per_cell-1))
      cone_size = 0
      cone_size(0: num_cells-1) = num_vertices_per_cell
      cone_orientations = 0
      depth = 1
      call DMPlexCreateFromDAG(dm, depth, num_points, cone_size, cones, &
           cone_orientations, vertex_coords, ierr); CHKERRQ(ierr)
   else ! rank > 0: create empty DMPlex
      num_points = [0, 0, 0]; cone_size = [0]
      cones = [0]; cone_orientations = [0]
      vertex_coords = [0]
      call DMPlexCreateFromDAG(dm, 1, num_points, cone_size, &
           cones, cone_orientations, vertex_coords, ierr); CHKERRQ(ierr)
   end if
   interp_dm = PETSC_NULL_OBJECT
   call DMPlexInterpolate(dm, interp_dm, ierr); CHKERRQ(ierr)
   call DMPlexCopyCoordinates(dm, interp_dm, ierr); CHKERRQ(ierr)
   dm = interp_dm
   deallocate(num_points, cone_size, cones, cone_orientations,
vertex_coords)
end subroutine create_1d_grid
subroutine create_partition_vector(dm, cell_dm, partition, ierr)
   ! Returns a DM and vector containing partitioning data
   implicit none
   DM, intent(in) :: dm
   DM, intent(out) :: cell_dm
   Vec, intent(out) :: partition
   ! Locals:
   MPI_Comm :: comm
   PetscMPIInt :: rank
   PetscSF :: sfPoint
   PetscSection :: coord_section
   Vec :: coordinates
   PetscSection :: cell_section
   PetscScalar, pointer :: part(:)
   PetscInt :: cStart, cEnd, c, off
   call DMGetCoordinateSection(dm, coord_section, ierr); CHKERRQ(ierr)
   call DMGetCoordinatesLocal(dm, coordinates, ierr); CHKERRQ(ierr)
   call DMClone(dm, cell_dm, ierr); CHKERRQ(ierr)
   call DMGetPointSF(dm, sfPoint, ierr); CHKERRQ(ierr)
   call DMSetPointSF(cell_dm, sfPoint, ierr); CHKERRQ(ierr)
   call DMSetCoordinateSection(cell_dm, coord_section, ierr); CHKERRQ(ierr)
   call DMSetCoordinatesLocal(cell_dm, coordinates, ierr); CHKERRQ(ierr)
   call PetscObjectGetComm(dm, comm, ierr); CHKERRQ(ierr)
   call PetscSectionCreate(comm, cell_section, ierr); CHKERRQ(ierr)
   call DMPlexGetHeightStratum(cell_dm, 0, cStart, cEnd, ierr);
CHKERRQ(ierr)
   call PetscSectionSetChart(cell_section, cStart, cEnd, ierr);
CHKERRQ(ierr)
   do c = cStart, cEnd-1
      call PetscSectionSetDof(cell_section, c, 1, ierr); CHKERRQ(ierr)
   end do
   call PetscSectionSetUp(cell_section, ierr); CHKERRQ(ierr)
   call DMSetDefaultSection(cell_dm, cell_section, ierr); CHKERRQ(ierr)
   call PetscSectionDestroy(cell_section, ierr); CHKERRQ(ierr)
   call DMCreateLocalVector(cell_dm, partition, ierr); CHKERRQ(ierr)
   call PetscObjectSetName(partition, "partition", ierr); CHKERRQ(ierr)
   call VecGetArrayF90(partition, part, ierr); CHKERRQ(ierr)
   call MPI_Comm_rank(comm, rank); CHKERRQ(ierr)
      call PetscSectionGetOffset(cell_section, c, off, ierr); CHKERRQ(ierr)
      part(off) = rank
   end do
   call VecRestoreArrayF90(partition, part, ierr); CHKERRQ(ierr)
end subroutine create_partition_vector
Dr Adrian Croucher
Department of Engineering Science
University of Auckland
New Zealand
tel 64-9-373-7599 ext 84611
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140407/5cd0968f/attachment.html>
