[petsc-dev] calling DMPlexPointLocalRef() from fortran
Fri Apr 4 08:31:28 CDT 2014
On Thu, Apr 3, 2014 at 11:41 PM, Adrian Croucher
<a.croucher at auckland.ac.nz>wrote:
> hi,
> What is the right way to call DMPlexPointLocalRef() from fortran?
Right now, there is none. Jed did not write a Fortran interface, and did
not turn off the automatic one which is non-functional.
> I have a test subroutine that I'm basically translating from the
> CreatePartitionVec() function in the TS ex 33 example problem.
> Near the end there's a loop which in C goes:
>   ierr = VecGetArray(*partition, &part);CHKERRQ(ierr);
>   for (c = cStart; c < cEnd; ++c) {
>     PetscScalar *p;
>     ierr = DMPlexPointLocalRef(*dmCell, c, part, &p);CHKERRQ(ierr);
>     p[0] = rank;
>   ierr = VecRestoreArray(*partition, &part);CHKERRQ(ierr);
> So in fortran I've done this:
>   call VecGetArrayF90(partition, part, ierr); CHKERRQ(ierr)
>   do c = cStart, cEnd-1
>     call DMPlexPointLocalRef(cell_dm, c, part, p, ierr); CHKERRQ(ierr)
Instead of this, use
  call DMPlexGetDefaultSection(cell_dm, section, ierr); (Move outside of
loop)
  call PetscSectionGetOffset(section, c, off, ierr);
  part(off) =rank
     Matt
    p(1) = rank
>  end do
>  call VecRestoreArrayF90(partition, part, ierr); CHKERRQ(ierr)
> where I've previously declared
>   PetscScalar, pointer :: part(:)
>   PetscScalar, pointer:: p(:)
> However the compiler complains:
> Error: Rank mismatch in argument 'array' at (1) (scalar and rank-1)
> It's not liking the 'part' argument, but I'm not sure how it's supposed to
> be passed in. Any clues?
> Cheers, Adrian
> Dr Adrian Croucher
> Department of Engineering Science
> University of Auckland
> New Zealand
> tel 64-9-373-7599 ext 84611
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140404/d8d58a89/attachment.html>
