[petsc-dev] Experimental GNU make build system
Thu May 23 15:24:14 CDT 2013
On Thu, 23 May 2013, Satish Balay wrote:
> On Thu, 23 May 2013, Jed Brown wrote:
> > Satish Balay <balay at mcs.anl.gov> writes:
> > >> > Since it works for 'make V=1' - perhaps we coud do something like:
> > >> > if cygwin: V=1
> > >> I can change the "quiet" setup logic.  Is there a variable identifying
> > >> cygwin in petscvariables?
> > > Not currently - but there is a configure check isCygwin() [all it does
> > > is check 'uname -s'] which can presumably set the variable.
> > > And top level configure.py does its own check by for '/usr/bin/cygcheck.exe'
> > Thanks, pushed.  Can you add your other cygwin patches to
> > 'jed/gnumake-cygwin'?
> but they are just hacks. will check on proper fixes..
Lisandro,
Any idea why this redirection from PetscStringize() -> PetscStringizeArg() was needed?
https://bitbucket.org/petsc/petsc/commits/59aaf35543f238554406f60a2c099071dfa3cd67
This breaks on windows when empty 'LOCDIR' is used with -D__INSDIR__=${LOCDIR}
[but reverting the above gets the compile going.]
Satish
$ make -f gmakefile PETSC_ARCH=arch-gmake
/home/balay/petsc.clone/bin/win32fe/win32fe cl -c -MT -wd4996 -Z7   -I/home/balay/petsc.clone/include -I/home/balay/petsc.clone/arch-gmake/include -I/cygdrive/c/Program\ Files/Microsoft\ HPC\ Pack\ 2012/Inc    -D__INSDIR__=  src/sys/info/verboseinfo.c -o arch-gmake/obj-gmake/src/sys/info/verboseinfo.o
verboseinfo.c
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(202) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(202) : error C2059: syntax error : ';'
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(202) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(204) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(204) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(215) : error C2143: syntax error : missing ')' before '*'
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(215) : error C2143: syntax error : missing '{' before '*'
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(215) : error C2059: syntax error : ')'
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(325) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(325) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(326) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(326) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(458) : error C2061: syntax error : identifier 'PetscIntStackCreate'
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(458) : error C2059: syntax error : ';'
C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(458) : error C2059: syntax error : 'type'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1618) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1618) : error C2059: syntax error : ';'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1618) : error C2059: syntax error : ','
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1619) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1619) : error C2059: syntax error : ','
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1620) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1620) : error C2059: syntax error : ','
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1628) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1628) : error C2059: syntax error : ','
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1677) : error C2061: syntax error : identifier 'PetscMemzero'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1677) : error C2059: syntax error : ';'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1677) : error C2059: syntax error : 'type'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1681) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1932) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1932) : error C2059: syntax error : ';'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1932) : error C2059: syntax error : ','
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1942) : error C2061: syntax error : identifier 'PetscMPIIntCast'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1942) : error C2059: syntax error : ';'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1942) : error C2059: syntax error : 'type'
c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1944) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(52) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(52) : error C2059: syntax error : ';'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(52) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(54) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(54) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(55) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(55) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(57) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(57) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(58) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(58) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(59) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(59) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(85) : error C2061: syntax error : identifier 'PetscInfoDeactivateClass'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(85) : error C2059: syntax error : ';'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(85) : error C2059: syntax error : 'type'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(87) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(116) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(116) : error C2059: syntax error : ';'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(116) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(127) : error C2143: syntax error : missing '{' before '*'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(179) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(179) : error C2059: syntax error : ';'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(179) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(180) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(180) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(181) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(181) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(187) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(187) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(191) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(191) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(194) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(194) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(195) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(195) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(196) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(196) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(198) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(198) : error C2059: syntax error : ','
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(201) : warning C4133: 'function' : incompatible types - from 'int *' to 'FILE *'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(201) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(201) : error C2059: syntax error : ','
gmakefile:100: recipe for target `arch-gmake/obj-gmake/src/sys/info/verboseinfo.o' failed
make: *** [arch-gmake/obj-gmake/src/sys/info/verboseinfo.o] Error 2
