[petsc-dev] Experimental GNU make build system
Thu May 23 15:32:01 CDT 2013
I see it now. Without that redirection - macro replacement of __INSDIR__ is not hapenning :(
Satish
__INSDIR__/home/balay/petsc.clone/include/../src/vec/vec/utils/vpscat.h:22: __FUNCT__="VecScatterBegin_BS" does not agree with PETSC_FUNCTION_NAME="VecScatterBegin_4"
__INSDIR__/home/balay/petsc.clone/include/../src/vec/vec/utils/vpscat.h:171: __FUNCT__="VecScatterEnd_BS" does not agree with PETSC_FUNCTION_NAME="VecScatterEnd_4"
On Thu, 23 May 2013, Satish Balay wrote:
> Lisandro,
> Any idea why this redirection from PetscStringize() -> PetscStringizeArg() was needed?
> https://bitbucket.org/petsc/petsc/commits/59aaf35543f238554406f60a2c099071dfa3cd67
> This breaks on windows when empty 'LOCDIR' is used with -D__INSDIR__=${LOCDIR}
> [but reverting the above gets the compile going.]
> Thanks,
> Satish
> $ make -f gmakefile PETSC_ARCH=arch-gmake
> /home/balay/petsc.clone/bin/win32fe/win32fe cl -c -MT -wd4996 -Z7   -I/home/balay/petsc.clone/include -I/home/balay/petsc.clone/arch-gmake/include -I/cygdrive/c/Program\ Files/Microsoft\ HPC\ Pack\ 2012/Inc    -D__INSDIR__=  src/sys/info/verboseinfo.c -o arch-gmake/obj-gmake/src/sys/info/verboseinfo.o
> verboseinfo.c
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(202) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(202) : error C2059: syntax error : ';'
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(202) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(204) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(204) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(215) : error C2143: syntax error : missing ')' before '*'
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(215) : error C2143: syntax error : missing '{' before '*'
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(215) : error C2059: syntax error : ')'
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(325) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(325) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(326) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(326) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(458) : error C2061: syntax error : identifier 'PetscIntStackCreate'
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(458) : error C2059: syntax error : ';'
> C:\cygwin\home\balay\PETSC~1.CLO\include\petsclog.h(458) : error C2059: syntax error : 'type'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1618) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1618) : error C2059: syntax error : ';'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1618) : error C2059: syntax error : ','
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1619) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1619) : error C2059: syntax error : ','
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1620) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1620) : error C2059: syntax error : ','
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1628) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1628) : error C2059: syntax error : ','
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1677) : error C2061: syntax error : identifier 'PetscMemzero'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1677) : error C2059: syntax error : ';'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1677) : error C2059: syntax error : 'type'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1681) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1932) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1932) : error C2059: syntax error : ';'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1932) : error C2059: syntax error : ','
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1942) : error C2061: syntax error : identifier 'PetscMPIIntCast'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1942) : error C2059: syntax error : ';'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1942) : error C2059: syntax error : 'type'
> c:\cygwin\home\balay\petsc.clone\include\petscsys.h(1944) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(52) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(52) : error C2059: syntax error : ';'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(52) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(54) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(54) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(55) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(55) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(57) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(57) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(58) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(58) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(59) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(59) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(85) : error C2061: syntax error : identifier 'PetscInfoDeactivateClass'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(85) : error C2059: syntax error : ';'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(85) : error C2059: syntax error : 'type'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(87) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(116) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(116) : error C2059: syntax error : ';'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(116) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(127) : error C2143: syntax error : missing '{' before '*'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(179) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(179) : error C2059: syntax error : ';'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(179) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(180) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(180) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(181) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(181) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(187) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(187) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(191) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(191) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(194) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(194) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(195) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(195) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(196) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(196) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(198) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(198) : error C2059: syntax error : ','
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(201) : warning C4133: 'function' : incompatible types - from 'int *' to 'FILE *'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(201) : warning C4003: not enough actual parameters for macro 'PetscStringizeArg'
> C:\cygwin\home\balay\PETSC~1.CLO\src\sys\info\verboseinfo.c(201) : error C2059: syntax error : ','
> gmakefile:100: recipe for target `arch-gmake/obj-gmake/src/sys/info/verboseinfo.o' failed
> make: *** [arch-gmake/obj-gmake/src/sys/info/verboseinfo.o] Error 2
