[petsc-dev] Experimental GNU make build system
Thu May 23 14:01:44 CDT 2013
On Thu, 23 May 2013, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> >> > Since it works for 'make V=1' - perhaps we coud do something like:
> >> > if cygwin: V=1
> >> I can change the "quiet" setup logic.  Is there a variable identifying
> >> cygwin in petscvariables?
> > Not currently - but there is a configure check isCygwin() [all it does
> > is check 'uname -s'] which can presumably set the variable.
> > And top level configure.py does its own check by for '/usr/bin/cygcheck.exe'
> Thanks, pushed.  Can you add your other cygwin patches to
> 'jed/gnumake-cygwin'?
but they are just hacks. will check on proper fixes..
satish
