[petsc-dev] removing sieve
Sat May 11 18:18:00 CDT 2013
Matt, I take it that you intend for this removal to be merged for
petsc-3.4 so that users are not distracted by something we aren't
supporting.  An alternative would be to add a #warning to petscdmmesh.h.
If we are deleting it from petsc-3.4, there are a few files that can
have more stuff deleted:
$ git grep -l 'ALE::'
bin/processSummary.py
config/PETSc/FEM.py
src/dm/impls/plex/plexfem.c
src/docs/doxygen/Doxyfile
src/snes/examples/tutorials/ex72.c
We can delete the sieve-dev mailing list and reference to it.
src/docs/website/miscellaneous/mailing-lists.html:          <td>: For Sieve users</td>
Update the FAQ to recommend DMPlex.
src/docs/website/documentation/faq.html:          use the Sieve construct in PETSc, this is a high
Remove src/docs/tex/manual/sieve.tex
Sieve is also referenced from src/docs/strategy.tex, which is an
outdated personal fragment that should probably also be deleted.
