[petsc-dev] removing sieve
Blaise A Bourdin bourdin at lsu.edu
Sat May 11 19:57:18 CDT 2013
Can we keep it in 3.4 with a warning? I have a lot more work to do before I can switch to dmplex.
Blaise
On May 11, 2013, at 6:18 PM, Jed Brown <jedbrown at mcs.anl.gov>
 wrote:
> Matt, I take it that you intend for this removal to be merged for
> petsc-3.4 so that users are not distracted by something we aren't
> supporting.  An alternative would be to add a #warning to petscdmmesh.h.
> If we are deleting it from petsc-3.4, there are a few files that can
> have more stuff deleted:
> $ git grep -l 'ALE::'
> bin/processSummary.py
> config/PETSc/FEM.py
> src/dm/impls/plex/plexfem.c
> src/docs/doxygen/Doxyfile
> src/snes/examples/tutorials/ex72.c
> We can delete the sieve-dev mailing list and reference to it.
> src/docs/website/miscellaneous/mailing-lists.html:          <td>: For Sieve users</td>
> Update the FAQ to recommend DMPlex.
> src/docs/website/documentation/faq.html:          use the Sieve construct in PETSc, this is a high
> Remove src/docs/tex/manual/sieve.tex
> Sieve is also referenced from src/docs/strategy.tex, which is an
> outdated personal fragment that should probably also be deleted.
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
