[petsc-dev] refactoring petsccusp.h needed
Chetan Jhurani chetan.jhurani at gmail.com
Tue Mar 19 18:22:37 CDT 2013
Thanks Karl.  The attached patch fixes the two issues you
mentioned.
I think the file extension comment in the code was a remnant
and is not really needed. I've removed it.
I have also removed CUSPARRAY macro from petsccusp.h and
used the full class name.  There are some implementation
files that still use the macro.  But fixing them is probably not
in the spirit of the public header cleanup effort and so I
have not touched them.
Chetan
> -----Original Message-----
> From: Karl Rupp [mailto:rupp at mcs.anl.gov]
> Sent: Tuesday, March 19, 2013 3:25 PM
> To: For users of the development version of PETSc
> Cc: Chetan Jhurani
> Subject: Re: [petsc-dev] refactoring petsccusp.h needed
> Hi Chetan,
> thanks for the patch. Looks good overall, just two more comments:
> * defining CUSPARRAY in a public header file is rude, as it is likely to
> interfere with user code. You should at least namespace it, or omit it
> for the prototypes completely.
> * The comment in the file header is
> "This should only be included in user code that uses CUSP directly and
> hence the file name ends with .cu"
> However, the file name is petsccusp.h...
> Please send me an updated patch and I'll commit the changes.
> @Barry: I think it's better to keep petsccusp.h as a separate file,
> otherwise you would have to include-guard <cusp/array1d.h> in petscvec.h
> Best regards,
> Karli
> On 03/19/2013 02:57 PM, Chetan Jhurani wrote:
> > Hi Barry / others,
> > Could you look at the attached diff, which avoids
> > exposing private functionality through the petsccusp
> > header?
> > It now exposes stuff relevant to VecCUSP* API calls
> > only and requires changes to these files.
> > include/petsccusp.h
> > src/snes/examples/tutorials/ex47cu.cu
> > src/vec/vec/impls/seq/seqcusp/cuspvecimpl.h
> > src/vec/vec/impls/seq/seqcusp/veccusp.cu
> > Paul is on travel.  Hence I am working on this.
> > Let me know if there are any issues.
> > Chetan
> >> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Paul
> Mullowney
> >> Sent: Friday, March 15, 2013 3:43 PM
> >> To: Barry Smith
> >> Cc: For users of the development version of PETSc
> >> Barry,
> >> Is March 21 still the target release date? I will look into this asap if
> >> that's the case but I've been trying to fix some other PETSc GPU
> >> problems in GMRES and BCGS algorithms.
> >> For GMRES, the current performance of VecMDot_SeqCUSP sucks. I have an
> >> solution, but I haven't tested all cases yet.
> >> For BCGS, some part of the algorithm is broken but I don't know what it
> >> is. By broken, I mean that CPU and GPU residuals diverge fairly quickly.
> >> -Paul
> >>>     Paul,
> >>>       We are thinking of a PETSc release around March 21. Before that time petsccusp.h
> >>> #if !defined(__PETSCCUSP_H)
> >>> #define __PETSCCUSP_H
> >>>       This should only be included in user code that uses CUSP directly and hence the file name
> ends
> >> with .cu
> >>> #include<../src/vec/vec/impls/dvecimpl.h>
> >>> #include<../src/vec/vec/impls/seq/seqcusp/cuspvecimpl.h>
> >>> #endif
> >>> so that ONLY the public interface of the stuff (what needs to be known to user code) is available
> >> and the rest is kept in the cuspvecimpl.h file. Maybe pets ccusp.h could be empty, I don't know).
> >>>      Do you think you can make that change and anything else that needs doing before the release?
> >>>      Thanks
> >>>       Barry
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130319/b528ab83/attachment.obj>
