[petsc-dev] refactoring petsccusp.h needed
Karl Rupp rupp at mcs.anl.gov
Tue Mar 19 17:24:37 CDT 2013
Hi Chetan,
thanks for the patch. Looks good overall, just two more comments:
* defining CUSPARRAY in a public header file is rude, as it is likely to
interfere with user code. You should at least namespace it, or omit it
for the prototypes completely.
* The comment in the file header is
"This should only be included in user code that uses CUSP directly and
hence the file name ends with .cu"
However, the file name is petsccusp.h...
Please send me an updated patch and I'll commit the changes.
@Barry: I think it's better to keep petsccusp.h as a separate file,
otherwise you would have to include-guard <cusp/array1d.h> in petscvec.h
Best regards,
Karli
On 03/19/2013 02:57 PM, Chetan Jhurani wrote:
> Hi Barry / others,
> Could you look at the attached diff, which avoids
> exposing private functionality through the petsccusp
> header?
> It now exposes stuff relevant to VecCUSP* API calls
> only and requires changes to these files.
> include/petsccusp.h
> src/snes/examples/tutorials/ex47cu.cu
> src/vec/vec/impls/seq/seqcusp/cuspvecimpl.h
> src/vec/vec/impls/seq/seqcusp/veccusp.cu
> Paul is on travel.  Hence I am working on this.
> Let me know if there are any issues.
> Chetan
>> -----Original Message-----
>> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Paul Mullowney
>> Sent: Friday, March 15, 2013 3:43 PM
>> To: Barry Smith
>> Cc: For users of the development version of PETSc
>> Subject: Re: [petsc-dev] refactoring petsccusp.h needed
>> Barry,
>> Is March 21 still the target release date? I will look into this asap if
>> that's the case but I've been trying to fix some other PETSc GPU
>> problems in GMRES and BCGS algorithms.
>> For GMRES, the current performance of VecMDot_SeqCUSP sucks. I have an
>> solution, but I haven't tested all cases yet.
>> For BCGS, some part of the algorithm is broken but I don't know what it
>> is. By broken, I mean that CPU and GPU residuals diverge fairly quickly.
>> -Paul
>>>     Paul,
>>>       We are thinking of a PETSc release around March 21. Before that time petsccusp.h
>>> #if !defined(__PETSCCUSP_H)
>>> #define __PETSCCUSP_H
>>>       This should only be included in user code that uses CUSP directly and hence the file name ends
>> with .cu
>>> #include<../src/vec/vec/impls/dvecimpl.h>
>>> #include<../src/vec/vec/impls/seq/seqcusp/cuspvecimpl.h>
>>> #endif
>>> so that ONLY the public interface of the stuff (what needs to be known to user code) is available
>> and the rest is kept in the cuspvecimpl.h file. Maybe pets ccusp.h could be empty, I don't know).
>>>      Do you think you can make that change and anything else that needs doing before the release?
>>>      Thanks
>>>       Barry
