[petsc-dev] refactoring petsccusp.h needed
Karl Rupp rupp at mcs.anl.gov
Tue Mar 19 20:45:29 CDT 2013
Hi Chetan,
thanks for the updated patch. I've commited it here:
https://bitbucket.org/petsc/petsc/commits/3c0b9f6fee0dc356fda99b643b018c35feeba883
and merged it to next. It will be merged to master after it passes our
nightly tests.
Best regards,
Karli
On 03/19/2013 06:22 PM, Chetan Jhurani wrote:
> Thanks Karl.  The attached patch fixes the two issues you
> mentioned.
> I think the file extension comment in the code was a remnant
> and is not really needed. I've removed it.
> I have also removed CUSPARRAY macro from petsccusp.h and
> used the full class name.  There are some implementation
> files that still use the macro.  But fixing them is probably not
> in the spirit of the public header cleanup effort and so I
> have not touched them.
> Chetan
>> -----Original Message-----
>> From: Karl Rupp [mailto:rupp at mcs.anl.gov]
>> Sent: Tuesday, March 19, 2013 3:25 PM
>> To: For users of the development version of PETSc
>> Cc: Chetan Jhurani
>> Subject: Re: [petsc-dev] refactoring petsccusp.h needed
>> Hi Chetan,
>> thanks for the patch. Looks good overall, just two more comments:
>> * defining CUSPARRAY in a public header file is rude, as it is likely to
>> interfere with user code. You should at least namespace it, or omit it
>> for the prototypes completely.
>> * The comment in the file header is
>> "This should only be included in user code that uses CUSP directly and
>> hence the file name ends with .cu"
>> However, the file name is petsccusp.h...
>> Please send me an updated patch and I'll commit the changes.
>> @Barry: I think it's better to keep petsccusp.h as a separate file,
>> otherwise you would have to include-guard <cusp/array1d.h> in petscvec.h
>> Best regards,
>> Karli
>> On 03/19/2013 02:57 PM, Chetan Jhurani wrote:
>>> Hi Barry / others,
>>> Could you look at the attached diff, which avoids
>>> exposing private functionality through the petsccusp
>>> header?
>>> It now exposes stuff relevant to VecCUSP* API calls
>>> only and requires changes to these files.
>>> include/petsccusp.h
>>> src/snes/examples/tutorials/ex47cu.cu
>>> src/vec/vec/impls/seq/seqcusp/cuspvecimpl.h
>>> src/vec/vec/impls/seq/seqcusp/veccusp.cu
>>> Paul is on travel.  Hence I am working on this.
>>> Let me know if there are any issues.
>>> Chetan
>>>> From: petsc-dev-bounces at mcs.anl.gov [mailto:petsc-dev-bounces at mcs.anl.gov] On Behalf Of Paul
>> Mullowney
>>>> Sent: Friday, March 15, 2013 3:43 PM
>>>> To: Barry Smith
>>>> Cc: For users of the development version of PETSc
>>>> Barry,
>>>> Is March 21 still the target release date? I will look into this asap if
>>>> that's the case but I've been trying to fix some other PETSc GPU
>>>> problems in GMRES and BCGS algorithms.
>>>> For GMRES, the current performance of VecMDot_SeqCUSP sucks. I have an
>>>> solution, but I haven't tested all cases yet.
>>>> For BCGS, some part of the algorithm is broken but I don't know what it
>>>> is. By broken, I mean that CPU and GPU residuals diverge fairly quickly.
>>>> -Paul
>>>>>      Paul,
>>>>>        We are thinking of a PETSc release around March 21. Before that time petsccusp.h
>>>>> #if !defined(__PETSCCUSP_H)
>>>>> #define __PETSCCUSP_H
>>>>>        This should only be included in user code that uses CUSP directly and hence the file name
>> ends
>>>> with .cu
>>>>> #include<../src/vec/vec/impls/dvecimpl.h>
>>>>> #include<../src/vec/vec/impls/seq/seqcusp/cuspvecimpl.h>
>>>>> #endif
>>>>> so that ONLY the public interface of the stuff (what needs to be known to user code) is available
>>>> and the rest is kept in the cuspvecimpl.h file. Maybe pets ccusp.h could be empty, I don't know).
>>>>>       Do you think you can make that change and anything else that needs doing before the release?
>>>>>       Thanks
>>>>>        Barry
