[petsc-dev] Build error in Cygwin
Mon Mar 18 08:27:50 CDT 2013
Do what the error message says.
On Mar 18, 2013 8:18 AM, "Chen Shapira" <chen2600 at gmail.com> wrote:
> Hi ,
> I'm building petsc in cygwin , and
> when running my configure command :
> ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe ifort'
> --with-cxx='win32fe cl' --with-mpi-dir="/cygdrive/C/Program Files
> (x86)/MPICH2" --download-f-blas-lapack=1 --with-clanguage=c
> --with-petsc-arch=arch-mswin-c-debug
> --CFLAGS=-D_CRT_SECURE_NO_DEPRECATE --with-debugging=0
> --ignore-cygwin-link --with-valgrind=0 --with-c2html=0
> --download-sowing=1 --with-hdf5=1
> --with-hdf5-include=/cygdrive/c/libraries/hdf5/include
> --with-hdf5-lib=\[/cygdrive/c/libraries/hdf5/libs/hdf5dll.lib,
> /cygdrive/c/libraries/hdf5/libs/hdf5_fortrandll.lib,/cygdrive/c/libraries/hdf5/libs/szip.lib,/cygdrive/c/libraries/hdf5/libs/zlib.lib\]
> I get the following message (in cygwin) :
>   The PETSc development repository has moved. The new repository can be
>   cloned using:
>     $ git clone https://bitbucket.org/petsc/petsc
>   or, using the Mercurial mirror:
>     $ hg clone https://bitbucket.org/petsc/petsc-hg
>   See the website for further details: https://bitbucket.org/petsc/petsc
> Could someone tell me how to continue ?
> I've downloaded petsc-dev and its buildsystem using : hg clone
> https://bitbucket.org/petsc/petsc-dev
> Please let me know how can I built it
> Thanks
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130318/f936165c/attachment.html>
