[petsc-dev] Build error in Cygwin
    Chen Shapira
    chen2600 at gmail.com
    Mon Mar 18 08:18:11 CDT 2013
Hi ,
I'm building petsc in cygwin , and
when running my configure command :
./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe ifort'
--with-cxx='win32fe cl' --with-mpi-dir="/cygdrive/C/Program Files
(x86)/MPICH2" --download-f-blas-lapack=1 --with-clanguage=c
--with-petsc-arch=arch-mswin-c-debug
--CFLAGS=-D_CRT_SECURE_NO_DEPRECATE --with-debugging=0
--ignore-cygwin-link --with-valgrind=0 --with-c2html=0
--download-sowing=1 --with-hdf5=1
--with-hdf5-include=/cygdrive/c/libraries/hdf5/include
--with-hdf5-lib=\[/cygdrive/c/libraries/hdf5/libs/hdf5dll.lib,
/cygdrive/c/libraries/hdf5/libs/hdf5_fortrandll.lib,/cygdrive/c/libraries/hdf5/libs/szip.lib,/cygdrive/c/libraries/hdf5/libs/zlib.lib\]
I get the following message (in cygwin) :
  The PETSc development repository has moved. The new repository can be
  cloned using:
    $ git clone https://bitbucket.org/petsc/petsc
  or, using the Mercurial mirror:
    $ hg clone https://bitbucket.org/petsc/petsc-hg
  See the website for further details: https://bitbucket.org/petsc/petsc
Could someone tell me how to continue ?
I've downloaded petsc-dev and its buildsystem using : hg clone
https://bitbucket.org/petsc/petsc-dev
Please let me know how can I built it
Thanks
