[petsc-dev] Build error in Cygwin
Chen Shapira chen2600 at gmail.com
Mon Mar 18 08:41:03 CDT 2013
the error message told me to download the regular petsc copy,
I need the petsc-dev copy (which I've obtained from bitbucket , as the
official petsc web-instructions said)
On Mon, Mar 18, 2013 at 3:27 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Do what the error message says.
> On Mar 18, 2013 8:18 AM, "Chen Shapira" <chen2600 at gmail.com> wrote:
>> Hi ,
>> I'm building petsc in cygwin , and
>> when running my configure command :
>> ./config/configure.py --with-cc='win32fe cl' --with-fc='win32fe ifort'
>> --with-cxx='win32fe cl' --with-mpi-dir="/cygdrive/C/Program Files
>> (x86)/MPICH2" --download-f-blas-lapack=1 --with-clanguage=c
>> --with-petsc-arch=arch-mswin-c-debug
>> --CFLAGS=-D_CRT_SECURE_NO_DEPRECATE --with-debugging=0
>> --ignore-cygwin-link --with-valgrind=0 --with-c2html=0
>> --download-sowing=1 --with-hdf5=1
>> --with-hdf5-include=/cygdrive/c/libraries/hdf5/include
>> --with-hdf5-lib=\[/cygdrive/c/libraries/hdf5/libs/hdf5dll.lib,
>> /cygdrive/c/libraries/hdf5/libs/hdf5_fortrandll.lib,/cygdrive/c/libraries/hdf5/libs/szip.lib,/cygdrive/c/libraries/hdf5/libs/zlib.lib\]
>> I get the following message (in cygwin) :
>>   The PETSc development repository has moved. The new repository can be
>>   cloned using:
>>     $ git clone https://bitbucket.org/petsc/petsc
>>   or, using the Mercurial mirror:
>>     $ hg clone https://bitbucket.org/petsc/petsc-hg
>>   See the website for further details: https://bitbucket.org/petsc/petsc
>> Could someone tell me how to continue ?
>> I've downloaded petsc-dev and its buildsystem using : hg clone
>> https://bitbucket.org/petsc/petsc-dev
>> Please let me know how can I built it
>> Thanks
