[petsc-dev] PETSc repositories have been moved
Tim Tautges tautges at mcs.anl.gov
Tue Mar 12 15:57:40 CDT 2013
On 03/12/2013 03:48 PM, Barry Smith wrote:
> On Mar 12, 2013, at 3:42 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Mar 12, 2013 at 4:30 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> On Mar 12, 2013, at 2:52 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
>>> Hi Richard,
>>> Jed and I set up detailed instructions on how to use Git and Mercurial:
>>> https://bitbucket.org/petsc/petsc/wiki/Home
>> Note that both Karl and Jed know git very well, so these pages will pretty much suck for new users.
>> I agree. That is why its important that its a Wiki.
> Because you perceive a Wiki as something that is very easy to change something in quickly.  I think in that sense
> Wikis are like PERL, it is very quick to put something together that looks powerful, but long term maintenance and
> general extension is impossible. Why not put all PETSc source code into the wiki then we can easily edit it without
> bothering with Emacs and shells?
In most systems, wikis are backed by a database*, so in practice there's little difference (with the added benefit that
a wiki gives you layout).
* - not sure about this in the case of bitbucket, but I'd be surprised if it wasn't.
Also, I find that infographics here help a bunch, like
http://mercurial.selenic.com/wiki/QuickReferenceCardsAndCheatSheets?action=AttachFile&do=get&target=Mercurial-Usage-v1.0bz-300dpi-color.png.
  I looked a few days ago and couldn't find a good one for git.  Especially with the conventions described for petsc
(which all seem reasonable), I think such a graphic would really help, as it's easy to confuse next vs. master vs.
branches and the movement between them.
- tim
> I am fine with putting that stuff there in the short term, but how about in the longer term having it as a subtree
> (subrepo?) in the petsc/src/docs/  directory?
> Barry
>> I checked one thing in this morning.
>> Matt
>> Barry
>>> In short, to get your changes merged back 'upstream', you still just need to send a pull request for petsc-hg on
>>> Bitbucket. :-)
>>> Best regards, Karli
>>> On 03/12/2013 02:42 PM, Richard Tran Mills wrote:
>>>> Hi Barry,
>>>> I will start using Git for working with petsc-dev when there are some clear instructions on the workflow we
>>>> should be using.  In the meantime I have some petsc-dev tasks on my to-do list and I plan to work using a fork
>>>> of petsc-hg.  To get my changes merged back "upstream", I assume I still just need to submit a pull request for
>>>> petsc-hg on BitBucket?
>>>> Thanks, Richard
>>>> On 3/12/13 12:16 PM, Barry Smith wrote:
>>>>> PETSc dev users,
>>>>> The PETSc repositories have been moved. They are at
>>>>> https::/bitbucket.org/petsc/petsc <http://bitbucket.org/petsc/petsc> (git version)
>>>>> https:/bitbucket.org/petsc/petsc-hg <http://bitbucket.org/petsc/petsc-hg> (Mecurial version)
>>>>> please reclone all your repositories and do not use the previous repository!
>>>>> You may make pull requests via bitbucket for either repository.   The Mecurial version is read only; active
>>>>> developers with write access will be working with the git version but the the Mecurial version will always be
>>>>> in sync with the master branch of the git version.
>>>>> Problems? Send email or bug one of Jed, Satish, Barry
>>>>> Barry
>>>>> Begin forwarded message:
>>>>>> *From: *Jed Brown <jedbrown at mcs.anl.gov <mailto:jedbrown at mcs.anl.gov>> *Subject: **petsc-hg* *Date: *March
>>>>>> 12, 2013 10:20:51 AM CDT *To: *Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
>>>>>> https://bitbucket.org/petsc/petsc-hg/
>>>>>> This is currently writable only by me. It will mirror 'master' from the Git repo and people can send pull
>>>>>> requests to it.
>>>> -- Richard Tran Mills, Ph.D. Computational Earth Scientist      | Joint Assistant Professor Hydrogeochemical
>>>> Dynamics Team     | EECS and Earth & Planetary Sciences Oak Ridge National Laboratory      | University of
>>>> Tennessee, Knoxville E-mail:rmills at ornl.gov   V: 865-241-3198http://climate.ornl.gov/~rmills
>> -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than
>> any results to which their experiments lead. -- Norbert Wiener
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
