[petsc-dev] PETSc repositories have been moved
Tue Mar 12 15:42:59 CDT 2013
On Tue, Mar 12, 2013 at 4:30 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Mar 12, 2013, at 2:52 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> > Hi Richard,
> > Jed and I set up detailed instructions on how to use Git and Mercurial:
> > https://bitbucket.org/petsc/petsc/wiki/Home
>   Note that both Karl and Jed know git very well, so these pages will
> pretty much suck for new users.
I agree. That is why its important that its a Wiki. I checked one thing in
this morning.
  Matt
>    Barry
> > In short, to get your changes merged back 'upstream', you still just
> need to send a pull request for petsc-hg on Bitbucket. :-)
> > Best regards,
> > Karli
> > On 03/12/2013 02:42 PM, Richard Tran Mills wrote:
> >> Hi Barry,
> >> I will start using Git for working with petsc-dev when there are some
> >> clear instructions on the workflow we should be using.  In the meantime
> >> I have some petsc-dev tasks on my to-do list and I plan to work using a
> >> fork of petsc-hg.  To get my changes merged back "upstream", I assume I
> >> still just need to submit a pull request for petsc-hg on BitBucket?
> >> Thanks,
> >> Richard
> >> On 3/12/13 12:16 PM, Barry Smith wrote:
> >>>    PETSc dev users,
> >>>     The PETSc repositories have been moved. They are at
> >>> https::/bitbucket.org/petsc/petsc <http://bitbucket.org/petsc/petsc>
> >>> (git version)
> >>> https:/bitbucket.org/petsc/petsc-hg
> >>> <http://bitbucket.org/petsc/petsc-hg> (Mecurial version)
> >>> please reclone all your repositories and do not use the previous
> >>> repository!
> >>> You may make pull requests via bitbucket for either repository.   The
> >>> Mecurial version is read only; active developers with write access
> >>> will be working with the git version but the the Mecurial version will
> >>> always be in sync with the master branch of the git version.
> >>> Problems? Send email or bug one of Jed, Satish, Barry
> >>>   Barry
> >>> Begin forwarded message:
> >>>> *From: *Jed Brown <jedbrown at mcs.anl.gov <mailto:jedbrown at mcs.anl.gov
> >>>> *Subject: **petsc-hg*
> >>>> *Date: *March 12, 2013 10:20:51 AM CDT
> >>>> *To: *Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
> >>>> https://bitbucket.org/petsc/petsc-hg/
> >>>> This is currently writable only by me. It will mirror 'master' from
> >>>> the Git repo and people can send pull requests to it.
> >> Richard Tran Mills, Ph.D.
> >> Computational Earth Scientist      | Joint Assistant Professor
> >> Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
> >> Oak Ridge National Laboratory      | University of Tennessee, Knoxville
> >> E-mail:rmills at ornl.gov   V: 865-241-3198http://climate.ornl.gov/~rmills
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130312/96c9700a/attachment.html>
