[petsc-dev] PETSc repositories have been moved
Tue Mar 12 15:30:44 CDT 2013
On Mar 12, 2013, at 2:52 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi Richard,
> Jed and I set up detailed instructions on how to use Git and Mercurial:
> https://bitbucket.org/petsc/petsc/wiki/Home
  Note that both Karl and Jed know git very well, so these pages will pretty much suck for new users.
   Barry
> In short, to get your changes merged back 'upstream', you still just need to send a pull request for petsc-hg on Bitbucket. :-)
> Best regards,
> Karli
> On 03/12/2013 02:42 PM, Richard Tran Mills wrote:
>> Hi Barry,
>> I will start using Git for working with petsc-dev when there are some
>> clear instructions on the workflow we should be using.  In the meantime
>> I have some petsc-dev tasks on my to-do list and I plan to work using a
>> fork of petsc-hg.  To get my changes merged back "upstream", I assume I
>> still just need to submit a pull request for petsc-hg on BitBucket?
>> Thanks,
>> Richard
>> On 3/12/13 12:16 PM, Barry Smith wrote:
>>>    PETSc dev users,
>>>     The PETSc repositories have been moved. They are at
>>> https::/bitbucket.org/petsc/petsc <http://bitbucket.org/petsc/petsc>
>>> (git version)
>>> https:/bitbucket.org/petsc/petsc-hg
>>> <http://bitbucket.org/petsc/petsc-hg> (Mecurial version)
>>> please reclone all your repositories and do not use the previous
>>> repository!
>>> You may make pull requests via bitbucket for either repository.   The
>>> Mecurial version is read only; active developers with write access
>>> will be working with the git version but the the Mecurial version will
>>> always be in sync with the master branch of the git version.
>>> Problems? Send email or bug one of Jed, Satish, Barry
>>>   Barry
>>> Begin forwarded message:
>>>> *From: *Jed Brown <jedbrown at mcs.anl.gov <mailto:jedbrown at mcs.anl.gov>>
>>>> *Subject: **petsc-hg*
>>>> *Date: *March 12, 2013 10:20:51 AM CDT
>>>> *To: *Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
>>>> https://bitbucket.org/petsc/petsc-hg/
>>>> This is currently writable only by me. It will mirror 'master' from
>>>> the Git repo and people can send pull requests to it.
>> Richard Tran Mills, Ph.D.
>> Computational Earth Scientist      | Joint Assistant Professor
>> Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
>> Oak Ridge National Laboratory      | University of Tennessee, Knoxville
>> E-mail:rmills at ornl.gov   V: 865-241-3198http://climate.ornl.gov/~rmills
