[petsc-dev] PETSc repositories have been moved
Karl Rupp rupp at mcs.anl.gov
Tue Mar 12 14:52:51 CDT 2013
Hi Richard,
Jed and I set up detailed instructions on how to use Git and Mercurial:
https://bitbucket.org/petsc/petsc/wiki/Home
In short, to get your changes merged back 'upstream', you still just
need to send a pull request for petsc-hg on Bitbucket. :-)
Best regards,
Karli
On 03/12/2013 02:42 PM, Richard Tran Mills wrote:
> Hi Barry,
> I will start using Git for working with petsc-dev when there are some
> clear instructions on the workflow we should be using.  In the meantime
> I have some petsc-dev tasks on my to-do list and I plan to work using a
> fork of petsc-hg.  To get my changes merged back "upstream", I assume I
> still just need to submit a pull request for petsc-hg on BitBucket?
> Thanks,
> Richard
> On 3/12/13 12:16 PM, Barry Smith wrote:
>>     PETSc dev users,
>>      The PETSc repositories have been moved. They are at
>> https::/bitbucket.org/petsc/petsc <http://bitbucket.org/petsc/petsc>
>> (git version)
>> https:/bitbucket.org/petsc/petsc-hg
>> <http://bitbucket.org/petsc/petsc-hg> (Mecurial version)
>> please reclone all your repositories and do not use the previous
>> repository!
>> You may make pull requests via bitbucket for either repository.   The
>> Mecurial version is read only; active developers with write access
>> will be working with the git version but the the Mecurial version will
>> always be in sync with the master branch of the git version.
>> Problems? Send email or bug one of Jed, Satish, Barry
>>    Barry
>> Begin forwarded message:
>>> *From: *Jed Brown <jedbrown at mcs.anl.gov <mailto:jedbrown at mcs.anl.gov>>
>>> *Subject: **petsc-hg*
>>> *Date: *March 12, 2013 10:20:51 AM CDT
>>> *To: *Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
>>> https://bitbucket.org/petsc/petsc-hg/
>>> This is currently writable only by me. It will mirror 'master' from
>>> the Git repo and people can send pull requests to it.
> Richard Tran Mills, Ph.D.
> Computational Earth Scientist      | Joint Assistant Professor
> Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
> Oak Ridge National Laboratory      | University of Tennessee, Knoxville
> E-mail:rmills at ornl.gov   V: 865-241-3198http://climate.ornl.gov/~rmills
