[petsc-dev] PETSc repositories have been moved
Mark F. Adams mark.adams at columbia.edu
Tue Mar 12 12:29:22 CDT 2013
This looks OK, it looks like BuildSystem has been assimilated.
On Mar 12, 2013, at 1:14 PM, "Bacon, Diana H" <Diana.Bacon at pnnl.gov> wrote:
> So I'm assuming that the instructions to build the new petsc-hg repository
> should read:
> Once Mercurial is installed obtain petsc-hg with the following:
> * hg clone https://bitbucket.org/petsc/petsc-hg
> * cd petsc-hg
> * edit .hg/hgrc and the two lines
>      [hooks]
> post-pull = "$HG" $HG_ARGS -u  $@ --cwd config/BuildSystem
> * hg clone https://bitbucket.org/petsc/buildsystem config/BuildSystem
> I get an error on the last step:
> warning: bitbucket.org certificate with fingerprint
> 24:9c:45:8b:9c:aa:ba:55:4e:01:6d:58:ff:e4:28:7d:2a:14:ae:3b not verified
> (check hostfingerprints or web.cacerts config setting)
> abort: destination 'config/BuildSystem' is not empty
> And if I:
> hg pull -u
> I get repeated warnings:
> pulling from https://bitbucket.org/petsc/petsc-hg
> searching for changes
> no changes found
> Is this expected behavior?
> __________________________________________________
> Diana Bacon
> Senior Research Scientist
> Pacific Northwest National Laboratory
> On 3/12/13 9:38 AM, "Karl Rupp" <rupp at mcs.anl.gov> wrote:
>> Hi Dave,
>> it should of course read
>> https://bitbucket.org/petsc/petsc    (git version)
>> https://bitbucket.org/petsc/petsc-hg (Mecurial version)
>> Best regards,
>> Karli
>> On 03/12/2013 11:27 AM, Nystrom, William D wrote:
>>> Are these URLs really correct?  The first one has two colons and one
>>> slash i.e. "https::/" instead of "https:// <https:///>" and the second
>>> one has a single
>>> colon and one slash i.e. "https:/" instead of "https://".
>>> Dave Nystrom
>>> LANL HPC-5
>>> Phone: 505-667-7913
>>> Email: wdn at lanl.gov
>>> Smail: Mail Stop B272
>>>        Group HPC-5
>>>        Los Alamos National Laboratory
>>>        Los Alamos, NM 87545
>>> *From:* petsc-dev-bounces at mcs.anl.gov [petsc-dev-bounces at mcs.anl.gov] on
>>> behalf of Barry Smith [bsmith at mcs.anl.gov]
>>> *Sent:* Tuesday, March 12, 2013 10:16 AM
>>> *To:* For users of the development version of PETSc
>>> *Subject:* [petsc-dev] PETSc repositories have been moved
>>>     PETSc dev users,
>>>      The PETSc repositories have been moved. They are at
>>> https::/bitbucket.org/petsc/petsc <http://bitbucket.org/petsc/petsc>
>>> (git version)
>>> https:/bitbucket.org/petsc/petsc-hg
>>> <http://bitbucket.org/petsc/petsc-hg> (Mecurial version)
>>> please reclone all your repositories and do not use the previous
>>> repository!
>>> You may make pull requests via bitbucket for either repository.   The
>>> Mecurial version is read only; active developers with write access will
>>> be working with the git version but the the Mecurial version will always
>>> be in sync with the master branch of the git version.
>>> Problems? Send email or bug one of Jed, Satish, Barry
>>>    Barry
>>> Begin forwarded message:
>>>> *From: *Jed Brown <jedbrown at mcs.anl.gov <mailto:jedbrown at mcs.anl.gov>>
>>>> *Subject: **petsc-hg*
>>>> *Date: *March 12, 2013 10:20:51 AM CDT
>>>> *To: *Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
>>>> https://bitbucket.org/petsc/petsc-hg/
>>>> This is currently writable only by me. It will mirror 'master' from
>>>> the Git repo and people can send pull requests to it.
