[petsc-dev] PETSc repositories have been moved
Tue Mar 12 12:33:39 CDT 2013
It is still available as a standalone package, but we merged it as a
subtree of petsc so that petsc users and developers do not need to think of
it as separate. We merge back to the standalone buildsystem.
On Mar 12, 2013 12:29 PM, "Mark F. Adams" <mark.adams at columbia.edu> wrote:
> This looks OK, it looks like BuildSystem has been assimilated.
> On Mar 12, 2013, at 1:14 PM, "Bacon, Diana H" <Diana.Bacon at pnnl.gov>
> wrote:
> > So I'm assuming that the instructions to build the new petsc-hg
> repository
> > should read:
> > Once Mercurial is installed obtain petsc-hg with the following:
> > * hg clone https://bitbucket.org/petsc/petsc-hg
> > * cd petsc-hg
> > * edit .hg/hgrc and the two lines
> >      [hooks]
> > post-pull = "$HG" $HG_ARGS -u  $@ --cwd config/BuildSystem
> > * hg clone https://bitbucket.org/petsc/buildsystem config/BuildSystem
> > I get an error on the last step:
> > warning: bitbucket.org certificate with fingerprint
> > 24:9c:45:8b:9c:aa:ba:55:4e:01:6d:58:ff:e4:28:7d:2a:14:ae:3b not verified
> > (check hostfingerprints or web.cacerts config setting)
> > abort: destination 'config/BuildSystem' is not empty
> > And if I:
> > hg pull -u
> > I get repeated warnings:
> > pulling from https://bitbucket.org/petsc/petsc-hg
> > searching for changes
> > no changes found
> > Is this expected behavior?
> > __________________________________________________
> > Diana Bacon
> > Senior Research Scientist
> > Pacific Northwest National Laboratory
> > On 3/12/13 9:38 AM, "Karl Rupp" <rupp at mcs.anl.gov> wrote:
> >> Hi Dave,
> >> it should of course read
> >> https://bitbucket.org/petsc/petsc    (git version)
> >> https://bitbucket.org/petsc/petsc-hg (Mecurial version)
> >> Best regards,
> >> Karli
> >> On 03/12/2013 11:27 AM, Nystrom, William D wrote:
> >>> Are these URLs really correct?  The first one has two colons and one
> >>> slash i.e. "https::/" instead of "https:// <https:///>" and the second
> >>> one has a single
> >>> colon and one slash i.e. "https:/" instead of "https://".
> >>> Dave Nystrom
> >>> LANL HPC-5
> >>> Phone: 505-667-7913
> >>> Email: wdn at lanl.gov
> >>> Smail: Mail Stop B272
> >>>        Group HPC-5
> >>>        Los Alamos National Laboratory
> >>>        Los Alamos, NM 87545
> >>> *From:* petsc-dev-bounces at mcs.anl.gov [petsc-dev-bounces at mcs.anl.gov]
> on
> >>> behalf of Barry Smith [bsmith at mcs.anl.gov]
> >>> *Sent:* Tuesday, March 12, 2013 10:16 AM
> >>> *To:* For users of the development version of PETSc
> >>> *Subject:* [petsc-dev] PETSc repositories have been moved
> >>>     PETSc dev users,
> >>>      The PETSc repositories have been moved. They are at
> >>> https::/bitbucket.org/petsc/petsc <http://bitbucket.org/petsc/petsc>
> >>> (git version)
> >>> https:/bitbucket.org/petsc/petsc-hg
> >>> <http://bitbucket.org/petsc/petsc-hg> (Mecurial version)
> >>> please reclone all your repositories and do not use the previous
> >>> repository!
> >>> You may make pull requests via bitbucket for either repository.   The
> >>> Mecurial version is read only; active developers with write access will
> >>> be working with the git version but the the Mecurial version will
> always
> >>> be in sync with the master branch of the git version.
> >>> Problems? Send email or bug one of Jed, Satish, Barry
> >>>    Barry
> >>> Begin forwarded message:
> >>>> *From: *Jed Brown <jedbrown at mcs.anl.gov <mailto:jedbrown at mcs.anl.gov
> >>>> *Subject: **petsc-hg*
> >>>> *Date: *March 12, 2013 10:20:51 AM CDT
> >>>> *To: *Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
> >>>> https://bitbucket.org/petsc/petsc-hg/
> >>>> This is currently writable only by me. It will mirror 'master' from
> >>>> the Git repo and people can send pull requests to it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130312/22ae318d/attachment.html>
