[petsc-dev] PETSc repositories have been moved
Tue Mar 12 12:16:51 CDT 2013
The PETSc website will be updated shortly. You do not need to clone
BuildSystem separately any more.
On Mar 12, 2013 12:14 PM, "Bacon, Diana H" <Diana.Bacon at pnnl.gov> wrote:
> So I'm assuming that the instructions to build the new petsc-hg repository
> should read:
> Once Mercurial is installed obtain petsc-hg with the following:
> * hg clone https://bitbucket.org/petsc/petsc-hg
> * cd petsc-hg
> * edit .hg/hgrc and the two lines
>       [hooks]
> post-pull = "$HG" $HG_ARGS -u  $@ --cwd config/BuildSystem
> * hg clone https://bitbucket.org/petsc/buildsystem config/BuildSystem
> I get an error on the last step:
> warning: bitbucket.org certificate with fingerprint
> 24:9c:45:8b:9c:aa:ba:55:4e:01:6d:58:ff:e4:28:7d:2a:14:ae:3b not verified
> (check hostfingerprints or web.cacerts config setting)
> abort: destination 'config/BuildSystem' is not empty
> And if I:
> hg pull -u
> I get repeated warnings:
> pulling from https://bitbucket.org/petsc/petsc-hg
> searching for changes
> no changes found
> Is this expected behavior?
> __________________________________________________
> Diana Bacon
> Senior Research Scientist
> Pacific Northwest National Laboratory
> On 3/12/13 9:38 AM, "Karl Rupp" <rupp at mcs.anl.gov> wrote:
> >Hi Dave,
> >it should of course read
> >https://bitbucket.org/petsc/petsc    (git version)
> >https://bitbucket.org/petsc/petsc-hg (Mecurial version)
> >Best regards,
> >Karli
> >On 03/12/2013 11:27 AM, Nystrom, William D wrote:
> >> Are these URLs really correct?  The first one has two colons and one
> >> slash i.e. "https::/" instead of "https:// <https:///>" and the second
> >> one has a single
> >> colon and one slash i.e. "https:/" instead of "https://".
> >> Dave Nystrom
> >> LANL HPC-5
> >> Phone: 505-667-7913
> >> Email: wdn at lanl.gov
> >> Smail: Mail Stop B272
> >>         Group HPC-5
> >>         Los Alamos National Laboratory
> >>         Los Alamos, NM 87545
> >> *From:* petsc-dev-bounces at mcs.anl.gov [petsc-dev-bounces at mcs.anl.gov]
> on
> >> behalf of Barry Smith [bsmith at mcs.anl.gov]
> >> *Sent:* Tuesday, March 12, 2013 10:16 AM
> >> *To:* For users of the development version of PETSc
> >> *Subject:* [petsc-dev] PETSc repositories have been moved
> >>      PETSc dev users,
> >>       The PETSc repositories have been moved. They are at
> >> https::/bitbucket.org/petsc/petsc <http://bitbucket.org/petsc/petsc>
> >> (git version)
> >> https:/bitbucket.org/petsc/petsc-hg
> >> <http://bitbucket.org/petsc/petsc-hg> (Mecurial version)
> >> please reclone all your repositories and do not use the previous
> >> repository!
> >> You may make pull requests via bitbucket for either repository.   The
> >> Mecurial version is read only; active developers with write access will
> >> be working with the git version but the the Mecurial version will always
> >> be in sync with the master branch of the git version.
> >> Problems? Send email or bug one of Jed, Satish, Barry
> >>     Barry
> >> Begin forwarded message:
> >>> *From: *Jed Brown <jedbrown at mcs.anl.gov <mailto:jedbrown at mcs.anl.gov>>
> >>> *Subject: **petsc-hg*
> >>> *Date: *March 12, 2013 10:20:51 AM CDT
> >>> *To: *Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
> >>> https://bitbucket.org/petsc/petsc-hg/
> >>> This is currently writable only by me. It will mirror 'master' from
> >>> the Git repo and people can send pull requests to it.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130312/6613215d/attachment.html>
