[petsc-dev] PETSc repositories have been moved
Bacon, Diana H Diana.Bacon at pnnl.gov
Tue Mar 12 12:14:11 CDT 2013
So I'm assuming that the instructions to build the new petsc-hg repository
should read:
Once Mercurial is installed obtain petsc-hg with the following:
* hg clone https://bitbucket.org/petsc/petsc-hg
* cd petsc-hg
* edit .hg/hgrc and the two lines
      [hooks]
post-pull = "$HG" $HG_ARGS -u  $@ --cwd config/BuildSystem
* hg clone https://bitbucket.org/petsc/buildsystem config/BuildSystem
I get an error on the last step:
warning: bitbucket.org certificate with fingerprint
24:9c:45:8b:9c:aa:ba:55:4e:01:6d:58:ff:e4:28:7d:2a:14:ae:3b not verified
(check hostfingerprints or web.cacerts config setting)
abort: destination 'config/BuildSystem' is not empty
And if I:
hg pull -u
I get repeated warnings:
pulling from https://bitbucket.org/petsc/petsc-hg
searching for changes
no changes found
Is this expected behavior?
__________________________________________________
Diana Bacon
Senior Research Scientist
Pacific Northwest National Laboratory
On 3/12/13 9:38 AM, "Karl Rupp" <rupp at mcs.anl.gov> wrote:
>Hi Dave,
>it should of course read
>https://bitbucket.org/petsc/petsc    (git version)
>https://bitbucket.org/petsc/petsc-hg (Mecurial version)
>Best regards,
>Karli
>On 03/12/2013 11:27 AM, Nystrom, William D wrote:
>> Are these URLs really correct?  The first one has two colons and one
>> slash i.e. "https::/" instead of "https:// <https:///>" and the second
>> one has a single
>> colon and one slash i.e. "https:/" instead of "https://".
>> Dave Nystrom
>> LANL HPC-5
>> Phone: 505-667-7913
>> Email: wdn at lanl.gov
>> Smail: Mail Stop B272
>>         Group HPC-5
>>         Los Alamos National Laboratory
>>         Los Alamos, NM 87545
>> *From:* petsc-dev-bounces at mcs.anl.gov [petsc-dev-bounces at mcs.anl.gov] on
>> behalf of Barry Smith [bsmith at mcs.anl.gov]
>> *Sent:* Tuesday, March 12, 2013 10:16 AM
>> *To:* For users of the development version of PETSc
>> *Subject:* [petsc-dev] PETSc repositories have been moved
>>      PETSc dev users,
>>       The PETSc repositories have been moved. They are at
>> https::/bitbucket.org/petsc/petsc <http://bitbucket.org/petsc/petsc>
>> (git version)
>> https:/bitbucket.org/petsc/petsc-hg
>> <http://bitbucket.org/petsc/petsc-hg> (Mecurial version)
>> please reclone all your repositories and do not use the previous
>> repository!
>> You may make pull requests via bitbucket for either repository.   The
>> Mecurial version is read only; active developers with write access will
>> be working with the git version but the the Mecurial version will always
>> be in sync with the master branch of the git version.
>> Problems? Send email or bug one of Jed, Satish, Barry
>>     Barry
>> Begin forwarded message:
>>> *From: *Jed Brown <jedbrown at mcs.anl.gov <mailto:jedbrown at mcs.anl.gov>>
>>> *Subject: **petsc-hg*
>>> *Date: *March 12, 2013 10:20:51 AM CDT
>>> *To: *Barry Smith <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>>
>>> https://bitbucket.org/petsc/petsc-hg/
>>> This is currently writable only by me. It will mirror 'master' from
>>> the Git repo and people can send pull requests to it.
