[petsc-dev] Internal and external symbols
Sean Farley sean at mcs.anl.gov
Tue Mar 5 21:25:05 CST 2013
Jed Brown writes:
> On Tue, Mar 5, 2013 at 8:54 PM, Sean Farley <sean at mcs.anl.gov> wrote:
>> Since mercurial was built on the concept of having a contiguous range of
>> revisions, it took quite a bit of work to implement filtering which is
>> what I was referring to (in git, this is accomplished by removing a
>> ref). So, we are talking about different things.
>> What you are asking for, it seems, is a log alias. If you only want the
>> current branch / bookmark / fork, then 'hg log -G -r :.' where -G will
>> give you the ascii graph. If you want a fancy one (with colors and
>> branch names that aren't 'default' and bookmarks), then you can use the
>> one I wrote:
>> [alias]
>> gll = log -G --pager=always
>>  --template="{label('changeset.{phase}', rev)}:{label('changeset.{phase}',
>> node|short)} {label('log.description',
>> sub('{',r'\{',desc|firstline|strip))}
>> {ifeq(branch,'default','',label('log.branch', '{branch} '))}{bookmarks %
>> \"{label('log.bookmark', '{bookmark} ')}\"}{tags % \"{label('log.tag',
>> '{tag} ')}\"}{label('log.date', date|shortdate)} by {label('log.user',
>> author|person)}"
>> and use it as 'hg gll -r :.' or again, make another alias,
>> gl = gll -l 25 -r :.
>> and use it as 'hg gl'. I have other useful aliases defined in my
>> dotfiles repo:
>> https://bitbucket.org/seanfarley/dotfiles/src/default/.hgrc#cl-188
> I know you can write aliases to provide reasonable behavior, but this
> doesn't help the new user. It seems like the Hg only option would be to
> have one repo that contains only one head ('master' in git lingo) and
> another repo that has all the topic branches and volatile integration
> branches, with the expectation that any users pulling from the volatile
> repo knows what they are doing. This is basically the situation we have now
> with release and dev.
Yes, that's basically what I was suggesting in my other email. It has
the feature of being easy to understand for the new user :-)
>> Ok, we have different meanings for namespace. Yes, what you describe is
>> exactly what I hope to accomplish with my revival of the remote-branches
>> extension.
> Cool, what will that interface look like?
Pretty much the same as the current remote-branches interface but adds
bookmarks. Not sure what else I have time, if any, for.
