[petsc-dev] Internal and external symbols
Sean Farley sean at mcs.anl.gov
Tue Mar 5 19:57:45 CST 2013
Jed Brown writes:
> On Tue, Mar 5, 2013 at 7:37 PM, Sean Farley <sean at mcs.anl.gov> wrote:
>> In mercurial, you'd do 'hg bookmark simp', 'hg push -B simp'. Jed would
>> 'hg pull -B simp' and complete the merge.
> One notable difference is that a git user does not see these unless they
> look for them. You can have hundreds of such branches without a typical
> user even knowing about them. In contrast, many normal hg commands show you
> these additional heads, often in a way that doesn't scale well.
Oh, also, you wouldn't have to see them in mercurial either. Just 'hg
pull -B simp' to pull only those changesets.
