[petsc-dev] Trying to get DMShell usable for PFLOTRAN
Richard Tran Mills rtm at eecs.utk.edu
Sun Mar 3 14:14:50 CST 2013
Jed,
It works fine with the patch.  Thanks for your help!
Regarding my question about having the DMShell object default to using
DMShellGlobalToLocalBegin()/End() if a scatter context has been
specified with DMShellSetGlobalToLocalVecScatter(), does that sound
appropriate?  I think the thing to do is to set
dm->ops->globaltolocalbegin to point to DMShellDefaultGlobalToLocalBegin
when the DMShell is created, and make DMShellDefaultGlobalToLocalBegin
check to see if a global to local VecScatter has been set and then
complain (with a helpful error message) if not.
--Richard
On 3/3/13 11:14 AM, Jed Brown wrote:
> Please squash the attached into your previous patch and test.
> On Sat, Mar 2, 2013 at 11:39 PM, Richard Tran Mills <rtm at eecs.utk.edu
> <mailto:rtm at eecs.utk.edu>> wrote:
>     Hi Jed (cc: petsc-dev, in case anyone else cares),
>     As we discussed on gchat, if you will grab
>     https://bitbucket.org/rmills/petsc-dev
>     https://bitbucket.org/rmills/pflotran-dev
>     you can see what I have been trying to do to get DMShell usable
>     for wrapping our PFLOTRAN unstructured grids in a DMs.  All of the
>     relevant PFLOTRAN changes are in discretization.F90.  As a first
>     step, I'm only trying to get the global-to-local operations
>     working using DMs.  I'm seeing the errors when I try to run a very
>     simple unstructured grid problem in
>     'example_problems/umesh/usg_5x4x3'.  If I just run PFLOTRAN in
>     there (one process, with no command-line arguments) it crashes
>     with lots of complaints along the lines of
>         [0]PETSC ERROR: PetscObjectGetFortranCallback() line 254 in
>         /Users/rmills/proj/petsc-dev_rmills/src/sys/objects/inherit.c
>         [0]PETSC ERROR: ourglobaltolocalend() line 80 in
>         /Users/rmills/proj/petsc-dev_rmills/src/dm/impls/shell/ftn-custom/zdmshellf.c
>         [0]PETSC ERROR: DMGlobalToLocalEnd() line 1668 in
>         /Users/rmills/proj/petsc-dev_rmills/src/dm/interface/dm.c
>     So it appears that I am doing something wrong.  I will admit that
>     so far I've just blindly emulated the examples you already had in
>     zdmshellf.c and I haven't taken the time to digest how the new
>     Fortran callback mechanism works, so maybe I'm just doing
>     something dumb with that.
>     On a somewhat related note, I've added a means to set a
>     GlobalToLocal scatter context for the DMShell, which I do in the
>     PFLOTRAN code, and the DMShellDefaultGlobalToLocalBegin/End, which
>     just performs the scatter using that 'gtol' context that is
>     stashed.  I am setting the 'gtol' scatter and then specifying that
>     the DMShellDefaultGlobalToLocalBegin/End be used.  I suppose it
>     makes more sense for the user to not have to set this if the
>     'gtol' has been given.  Should I make the
>     dm->ops->globaltolocalbegin point to
>     DMShellDefaultGlobalToLocalBegin when the DMShell is created, and
>     have that function check to see if the 'gtol' pointer is indeed
>     set to something?
>     --Richard
>     Richard Tran Mills, Ph.D.
>     Computational Earth Scientist      | Joint Assistant Professor
>     Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary
>     Sciences
>     Oak Ridge National Laboratory      | University of Tennessee,
>     Knoxville
>     E-mail: rmills at ornl.gov <mailto:rmills at ornl.gov>  V: 865-241-3198
>     <tel:865-241-3198> http://climate.ornl.gov/~rmills
>     <http://climate.ornl.gov/%7Ermills>
Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
Oak Ridge National Laboratory      | University of Tennessee, Knoxville
E-mail: rmills at ornl.gov  V: 865-241-3198 http://climate.ornl.gov/~rmills
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130303/4a158e02/attachment.html>
