[petsc-dev] Trying to get DMShell usable for PFLOTRAN
Sun Mar 3 10:14:22 CST 2013
Please squash the attached into your previous patch and test.
On Sat, Mar 2, 2013 at 11:39 PM, Richard Tran Mills <rtm at eecs.utk.edu>wrote:
> Hi Jed (cc: petsc-dev, in case anyone else cares),
> As we discussed on gchat, if you will grab
>   https://bitbucket.org/rmills/**petsc-dev<https://bitbucket.org/rmills/petsc-dev>
>   https://bitbucket.org/rmills/**pflotran-dev<https://bitbucket.org/rmills/pflotran-dev>
> you can see what I have been trying to do to get DMShell usable for
> wrapping our PFLOTRAN unstructured grids in a DMs.  All of the relevant
> PFLOTRAN changes are in discretization.F90.  As a first step, I'm only
> trying to get the global-to-local operations working using DMs.  I'm seeing
> the errors when I try to run a very simple unstructured grid problem in
> 'example_problems/umesh/usg_**5x4x3'.  If I just run PFLOTRAN in there
> (one process, with no command-line arguments) it crashes with lots of
> complaints along the lines of
>  [0]PETSC ERROR: PetscObjectGetFortranCallback(**) line 254 in
>> /Users/rmills/proj/petsc-dev_**rmills/src/sys/objects/**inherit.c
>> [0]PETSC ERROR: ourglobaltolocalend() line 80 in
>> /Users/rmills/proj/petsc-dev_**rmills/src/dm/impls/shell/ftn-**
>> custom/zdmshellf.c
>> [0]PETSC ERROR: DMGlobalToLocalEnd() line 1668 in
>> /Users/rmills/proj/petsc-dev_**rmills/src/dm/interface/dm.c
> So it appears that I am doing something wrong.  I will admit that so far
> I've just blindly emulated the examples you already had in zdmshellf.c and
> I haven't taken the time to digest how the new Fortran callback mechanism
> works, so maybe I'm just doing something dumb with that.
> On a somewhat related note, I've added a means to set a GlobalToLocal
> scatter context for the DMShell, which I do in the PFLOTRAN code, and the
> DMShellDefaultGlobalToLocalBeg**in/End, which just performs the scatter
> using that 'gtol' context that is stashed.  I am setting the 'gtol' scatter
> and then specifying that the DMShellDefaultGlobalToLocalBeg**in/End be
> used.  I suppose it makes more sense for the user to not have to set this
> if the 'gtol' has been given.  Should I make the
> dm->ops->globaltolocalbegin point to DMShellDefaultGlobalToLocalBeg**in
> when the DMShell is created, and have that function check to see if the
> 'gtol' pointer is indeed set to something?
> --Richard
> Richard Tran Mills, Ph.D.
> Computational Earth Scientist      | Joint Assistant Professor
> Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
> Oak Ridge National Laboratory      | University of Tennessee, Knoxville
> E-mail: rmills at ornl.gov  V: 865-241-3198 http://climate.ornl.gov/~**rmills<http://climate.ornl.gov/~rmills>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130303/d881751e/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130303/d881751e/attachment.obj>
