[petsc-dev] Trying to get DMShell usable for PFLOTRAN
Richard Tran Mills rtm at eecs.utk.edu
Sat Mar 2 23:39:42 CST 2013
Hi Jed (cc: petsc-dev, in case anyone else cares),
As we discussed on gchat, if you will grab
   https://bitbucket.org/rmills/petsc-dev
   https://bitbucket.org/rmills/pflotran-dev
you can see what I have been trying to do to get DMShell usable for
wrapping our PFLOTRAN unstructured grids in a DMs.  All of the relevant
PFLOTRAN changes are in discretization.F90.  As a first step, I'm only
trying to get the global-to-local operations working using DMs.  I'm
seeing the errors when I try to run a very simple unstructured grid
problem in 'example_problems/umesh/usg_5x4x3'.  If I just run PFLOTRAN
in there (one process, with no command-line arguments) it crashes with
lots of complaints along the lines of
> [0]PETSC ERROR: PetscObjectGetFortranCallback() line 254 in
> /Users/rmills/proj/petsc-dev_rmills/src/sys/objects/inherit.c
> [0]PETSC ERROR: ourglobaltolocalend() line 80 in
> /Users/rmills/proj/petsc-dev_rmills/src/dm/impls/shell/ftn-custom/zdmshellf.c
> [0]PETSC ERROR: DMGlobalToLocalEnd() line 1668 in
> /Users/rmills/proj/petsc-dev_rmills/src/dm/interface/dm.c
So it appears that I am doing something wrong.  I will admit that so far
I've just blindly emulated the examples you already had in zdmshellf.c
and I haven't taken the time to digest how the new Fortran callback
mechanism works, so maybe I'm just doing something dumb with that.
On a somewhat related note, I've added a means to set a GlobalToLocal
scatter context for the DMShell, which I do in the PFLOTRAN code, and
the DMShellDefaultGlobalToLocalBegin/End, which just performs the
scatter using that 'gtol' context that is stashed.  I am setting the
'gtol' scatter and then specifying that the
DMShellDefaultGlobalToLocalBegin/End be used.  I suppose it makes more
sense for the user to not have to set this if the 'gtol' has been
given.  Should I make the dm->ops->globaltolocalbegin point to
DMShellDefaultGlobalToLocalBegin when the DMShell is created, and have
that function check to see if the 'gtol' pointer is indeed set to something?
--Richard
Richard Tran Mills, Ph.D.
Computational Earth Scientist      | Joint Assistant Professor
Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
Oak Ridge National Laboratory      | University of Tennessee, Knoxville
E-mail: rmills at ornl.gov  V: 865-241-3198 http://climate.ornl.gov/~rmills
