[petsc-dev] [petsc-maint] Who fucked up the repository?
Sat Jun 15 15:47:43 CDT 2013
On Sat, Jun 15, 2013 at 10:44 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hey,
>  1) I ran the push again, even after issuing the command above, and still
>> got the same error
> > 2) How do I update my copy of 3.4.1? I pulled every branch and did a
> fetch.
> Did you try `git pull --tags` and/or `git fetch --tags`?
Yes, that worked. I cannot understand why this tag was different from all
the others.
   Matt
> Best regards,
> Karli
>      Matt
>>     Best regards,
>>     Karli
>>     On 06/15/2013 03:23 PM, Matthew Knepley wrote:
>>         I get this every time I try to push a branch:
>>         git -c diff.mnemonicprefix=false -c core.quotepath=false push -v
>>         --tags
>>         origin knepley/pylith:knepley/pylith
>>         Pushing to git at bitbucket.org:petsc/petsc
>>         To git at bitbucket.org:petsc/petsc
>>            = [up to date]      v2.0.29 -> v2.0.29
>>            = [up to date]      v2.1.0 -> v2.1.0
>>            = [up to date]      v2.3.2 -> v2.3.2
>>            = [up to date]      v2.3.3 -> v2.3.3
>>            = [up to date]      v3.0.0 -> v3.0.0
>>            = [up to date]      v3.1 -> v3.1
>>            = [up to date]      v3.2 -> v3.2
>>            = [up to date]      v3.3 -> v3.3
>>            = [up to date]      v3.4 -> v3.4
>>              3d2e007..e4fc00d  knepley/pylith -> knepley/pylith
>>            ! [rejected]        v3.4.1 -> v3.4.1 (non-fast-forward)
>>         updating local tracking ref 'refs/remotes/origin/knepley/_**
>> _pylith'
>>         error: failed to push some refs to 'git at bitbucket.org:petsc/__**
>> petsc'
>>         hint: Updates were rejected because a pushed branch tip is
>>         behind its remote
>>         hint: counterpart. Check out this branch and merge the remote
>>         changes
>>         hint: (e.g. 'git pull') before pushing again.
>>         hint: See the 'Note about fast-forwards' in 'git push --help'
>>         for details.
>>         Completed with errors, see above
>>         If I remove --tags, then it works.
>>              Matt
>>         What most experimenters take for granted before they begin their
>>         experiments is infinitely more interesting than any results to
>> which
>>         their experiments lead.
>>         -- Norbert Wiener
>> experiments is infinitely more interesting than any results to which
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130615/bfdfb46a/attachment.html>
