[petsc-dev] [petsc-maint] Who fucked up the repository?
Karl Rupp rupp at mcs.anl.gov
Sat Jun 15 15:44:33 CDT 2013
Hey,
> 1) I ran the push again, even after issuing the command above, and still
> got the same error
 > 2) How do I update my copy of 3.4.1? I pulled every branch and did a
fetch.
Did you try `git pull --tags` and/or `git fetch --tags`?
Best regards,
Karli
>     Matt
>     Best regards,
>     Karli
>     On 06/15/2013 03:23 PM, Matthew Knepley wrote:
>         I get this every time I try to push a branch:
>         git -c diff.mnemonicprefix=false -c core.quotepath=false push -v
>         --tags
>         origin knepley/pylith:knepley/pylith
>         Pushing to git at bitbucket.org:petsc/petsc
>         To git at bitbucket.org:petsc/petsc
>            = [up to date]      v2.0.29 -> v2.0.29
>            = [up to date]      v2.1.0 -> v2.1.0
>            = [up to date]      v2.3.2 -> v2.3.2
>            = [up to date]      v2.3.3 -> v2.3.3
>            = [up to date]      v3.0.0 -> v3.0.0
>            = [up to date]      v3.1 -> v3.1
>            = [up to date]      v3.2 -> v3.2
>            = [up to date]      v3.3 -> v3.3
>            = [up to date]      v3.4 -> v3.4
>              3d2e007..e4fc00d  knepley/pylith -> knepley/pylith
>            ! [rejected]        v3.4.1 -> v3.4.1 (non-fast-forward)
>         updating local tracking ref 'refs/remotes/origin/knepley/__pylith'
>         error: failed to push some refs to 'git at bitbucket.org:petsc/__petsc'
>         hint: Updates were rejected because a pushed branch tip is
>         behind its remote
>         hint: counterpart. Check out this branch and merge the remote
>         changes
>         hint: (e.g. 'git pull') before pushing again.
>         hint: See the 'Note about fast-forwards' in 'git push --help'
>         for details.
>         Completed with errors, see above
>         If I remove --tags, then it works.
>              Matt
>         What most experimenters take for granted before they begin their
>         experiments is infinitely more interesting than any results to which
>         their experiments lead.
>         -- Norbert Wiener
> -- Norbert Wiener
