[petsc-dev] spectral deferred correction (SDC) time stepper
Mon Jun 10 20:40:18 CDT 2013
  Matthew
   You should make a pull request at https://bitbucket.org/petsc/petsc and we can comment on the code and suggest changes if appropriate.
   Barry
On Jun 10, 2013, at 5:19 PM, Matthew Emmett <memmett at gmail.com> wrote:
> Hi again,
> Barry, thanks for the welcome -- hopefully my code is up to snuff :)
> I pushed my work so far on SDC to the memmett/tssdc branch of my fork on bitbucket (bitbucket.org/memmett/petsc).
> I have tried a few examples and it seems to be working (under the eye-ball norm).  I will try to create some formal convergence plots to convince myself that it is actually working.  Aside from that, are there any particular tests that I should do?
> Thanks,
> Matthew
