[petsc-dev] spectral deferred correction (SDC) time stepper
Matthew Emmett memmett at gmail.com
Mon Jun 10 23:09:04 CDT 2013
Hi Barry,
Alrighty, I created a pull request...
Enjoy,
Matthew
On Mon, Jun 10, 2013 at 6:40 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Matthew
>    You should make a pull request at https://bitbucket.org/petsc/petscand we can comment on the code and suggest changes if appropriate.
>    Barry
> On Jun 10, 2013, at 5:19 PM, Matthew Emmett <memmett at gmail.com> wrote:
> > Hi again,
> > Barry, thanks for the welcome -- hopefully my code is up to snuff :)
> > I pushed my work so far on SDC to the memmett/tssdc branch of my fork on
> bitbucket (bitbucket.org/memmett/petsc).
> > I have tried a few examples and it seems to be working (under the
> eye-ball norm).  I will try to create some formal convergence plots to
> convince myself that it is actually working.  Aside from that, are there
> any particular tests that I should do?
> > Thanks,
> > Matthew
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130610/375e7fef/attachment.html>
