[petsc-dev] ABI-compatible debug and optimized builds
Karl Rupp rupp at mcs.anl.gov
Mon Jun 10 09:18:57 CDT 2013
Hi Lisandro,
 > PS: This branch show be merged to "maint", but we really need to test
> it in "next" before that. How should I make the pull request?
As your branch is within the PETSc repository already, you can also
merge it to next directly, i.e.
$> git checkout next
$> git pull
$> git merge dalcinl/libpetsc-abi
(then test it in next, push the results if everything works out and wait
for results of nightly tests)
Best regards,
Karli
