[petsc-dev] GNUPackage working with ./configure yet made?
Mon Jun 3 22:37:21 CDT 2013
  Matt,
   Could GNUPackage be enhanced to check if the ./configure file exists (for packages downloaded from their repository that won't have a ./configure already) and generate the ./configure file when needed automatically?
    For example, with moab from its repository one needs to run
   autoreconf -fi
  If for some reason, the autoreconf command is not available,
  the following sequence of commands should have the same result:
    autoheader
    aclocal -I m4
    libtoolize -f
    autoconf
    automake -a
to create the ./configure file.
   Thanks
    Barry
