[petsc-dev] Petsc can't find gcc , on CentOS
Chen Shapira chen2600 at gmail.com
Thu Jun 6 06:21:44 CDT 2013
I'm building petsc-dev under CentOS 6 ,
I keep getting the error :
"C compiler you provided with -with-cc=gcc does not work"
The problem is I do have gcc , g++ and gfortran installed.
Any help ?
Thanks
Chen
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130606/318a3a09/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130606/318a3a09/attachment.obj>
