[petsc-dev] Experimental GNU make build system
Matthew Knepley
knepley at gmail.com
Mon Jun 3 18:01:28 CDT 2013
On Mon, Jun 3, 2013 at 6:13 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Jed Brown <jedbrown at mcs.anl.gov> writes:
> > Why pass it to the linker?
> Matt, is it going to break something (builder.py?) to only test the
> compiler?
I guess we will find out, and then one of us will be on the ball enough to
comment the behavior.
Matt
> > On May 29, 2013 8:32 AM, "Matthew Knepley" <knepley at gmail.com> wrote:
> >> On Wed, May 29, 2013 at 9:00 AM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> >>> On Tue, 28 May 2013, Satish Balay wrote:
> >>> > Yet to check:
> >>> > - configure check for '-MMD -MP' stuff..
> >>> I see there is already a configure test for this in
> >>> config/BuildSystem/config/compilers.py using -with-dependencies=1
> >>> [default] - but no makefile flag is set.
> >> Thats fine.
> >>> So perhaps the following fix? [in balay/gmake-config-dpecheck]
> https://bitbucket.org/petsc/petsc/commits/ee7bb8786b51b19508b610eb8895baeeae528351
> >>> Matt, BTW: does this thing have to do a link test using -MMD?
> >>> [Shouldn't it be a compile only test?]
> >> This is to make sure the flag does not screw up links.
> >> Matt
> >>> thanks,
> >>> Satish
> >> What most experimenters take for granted before they begin their
> >> experiments is infinitely more interesting than any results to which
> their
> >> experiments lead.
> >> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130603/f2457448/attachment.html>
