[petsc-dev] windows fixes.
Mon Jul 1 15:51:21 CDT 2013
On Mon, 1 Jul 2013, Jed Brown wrote:
> Satish Balay <balay at mcs.anl.gov> writes:
> >         CONFIGURATION CRASH  (Please send configure.log to petsc-maint at mcs.anl.gov)
> > 'gcc'  File "/sandbox/petsc/petsc.clone/config/configure.py", line 293, in petsc_configure
> >     framework.configure(out = sys.stdout)
> >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/framework.py", line 942, in configure
> >     child.configure()
> >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/compilerFlags.py", line 113, in configure
> >     self.executeTest(self.configureCompilerFlags)
> >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/base.py", line 126, in executeTest
> >     ret = test(*args,**kargs)
> >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/compilerFlags.py", line 97, in configureCompilerFlags
> >     flags = options.getCompilerFlags(language, self.setCompilers.getCompiler(), bopt)
> >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/compilerOptions.py", line 212, in getCompilerFlags
> >     flags = self.getCFlags(compiler, bopt)
> >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/compilerOptions.py", line 19, in getCFlags
> >     if config.setCompilers.Configure.isGNU(compiler) or config.setCompilers.Configure.isClang(compiler):
> >   File "/sandbox/petsc/petsc.clone/config/BuildSystem/config/util.py", line 68, in __call__
> >     return self[args]
> What exception is raised?
I don't know how to check that.
You can reproduce this on 'cg' by running [on next] ./config/examples/arch-linux-gcc-absoft.py
Satish
